GTA clone or not
Old Aug 7, 2007 | 02:04 PM
  #21
tarafied1's Avatar
tarafied1
Default RE: GTA clone or not
ORIGINAL: james_topless67
I think I might need to spend some time in the gym doing leg presses so I can stop the car.
I know what you mean, I have a 67 hardtop with manual (Granada) disc brakes and no PS with a big block. Its impossible to parralel park! It will stop but you may need to use both feet. I'm looking into a booster that will fit with the 429.
Old Aug 7, 2007 | 03:21 PM
  #22
05SDI's Avatar
05SDI
tarafied that pic in your sig SADDENS me!!!! No really it does!!!
Old Aug 7, 2007 | 03:51 PM
  #23
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: tarafied1
I can lock all four wheels on Ol' Yeller and lay rubber for several feet while stopping with the shoe brakes. Now, without ABS brakes, the Granada brakes will do the same. Whenever you lock down the wheels, you lose control. Just learn to not drive close behind another car no matter at what speed you are driving. The rule of the thumb is to mark with something on the side of the road when the car in front of you passes it, then count 3 seconds before you arrive at the same spot. You will be surprised how far that will put you behind the car in front of you. That is the buffer you need with any brakes that are not ABS.
Old Aug 7, 2007 | 04:03 PM
  #24
tarafied1's Avatar
tarafied1
ORIGINAL: 05SDI
I know, I took that picture in a junkyard when I was scrounging for parts. I have many more pics that will make you sick!
Soaring,
I agree. I have had the Granada fronts for a few years and so far no complaints. I just notice a huge dif when I go from the Mustang to my daily driver. My dad has a 66 with non-power drums and he drives it pretty regularly. His only complaint is on the hills of Kentucky they do get hot and fade after a work out but he has learned to down shift and engine brake as much as possible.
[IMG]local://upfiles/56180/F36F01B9C47F493ABB05D7B61F9A4C98.jpg[/IMG]
[IMG]local://upfiles/56180/0CB8D5F7B16E4D888603CAAA0F57145F.jpg[/IMG]
[IMG]local://upfiles/56180/E75BF1BF049F4665A665127E83AE1164.jpg[/IMG]
[IMG]local://upfiles/56180/26FF8F96AB6344CA9D19B165CA29AB57.jpg[/IMG]
Old Aug 7, 2007 | 04:55 PM
  #25
Soaring's Avatar
Soaring
I ♥ Acer
One of the first things I taught my son to do when he learned to drive was to downshift before coming to a stop. That's just one of the many reasons why I prefer a manual transmission. Yes, the mountain driving will cause shoe brakes to heat up faster than pads. That is one of the negatives besides getting wet and not working.
But, as far as actually stopping at a shorter distance, I beg to differ because both systems will lock the brakes, and when that happens you will lose control even if you have pads.
Old Aug 7, 2007 | 06:47 PM
  #26
tarafied1's Avatar
tarafied1
no aurguement here, if the tires are locked it really doesn't matter what kind of brakes you have.
Old Aug 7, 2007 | 07:12 PM
  #27
sarNz's Avatar
sarNz
I think clones are great, as long as you don't try to screw someone out of the money later on. Think about it, it requires more work and dedication to make a clone than to buy an original!
Really though, what I'm waiting for now is to graduate college, get some real money, and buy one of those Dynacorn repo bodies. It may not be the original but you know what, it's like them making the old mustang for the new generation. You older guys shouldn't get to have all the fun! Another reason I want one of those is because -> Less work, everything will be brand new into it, I can build it exactly how I want, and keep it forever! I would call it a mustang, but I would classify it as a custom car. The real mustangs were made back in the day.
Old Aug 7, 2007 | 07:36 PM
  #28
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: sarNz
Thank you for that clarification. The real Mustangs were made back during the day.
Old Aug 7, 2007 | 10:44 PM
  #29
andrewmp6's Avatar
andrewmp6
tarafield where you find them mustang at.for that brake booster talk to http://www.mpbrakes.com/ or http://www.abspowerbrake.com/
Old Aug 8, 2007 | 10:40 AM
  #30
james_topless67's Avatar
james_topless67
Can you use the stock shifter with an AOD trans?
Does anyone have any experience with the Gear Vendors overdrive unit?
