GTA clone or not
Old Aug 8, 2007 | 10:47 AM
  #31
iamdiffrnt's Avatar
iamdiffrnt
Default RE: GTA clone or not
Yes, you can use the stock shifter with an AOD. You have to either modify your linkage, and the lever on transslightly (I believe, do a search), or you can buy a linkage kit (what I did).
Gearvendor, I've only heard good things about it, however, you can buy a freshly built AOD for less.
Old Aug 8, 2007 | 01:26 PM
  #32
james_topless67's Avatar
james_topless67
ORIGINAL: iamdiffrnt
Thanks for the info.
When you use your stock shifter in drive I asume the trans is on OD how do you get to the other 3 gears?
Old Aug 9, 2007 | 10:40 AM
  #33
iamdiffrnt's Avatar
iamdiffrnt
The shift pattern for the AOD is: P R N OD D L.
So there aren't any more gears. L is 1st & 2nd.
So to re- map:
P R ND 2 1 becomes
P R N OD D L
Hope this is what you wanted.
Edited to line up shift patterns.
Old Aug 9, 2007 | 11:03 AM
  #34
SS4LUNCH's Avatar
SS4LUNCH
Go ahead and make it a GTA clone. It's your car. The real deal is priced out of my range personally. I am going to build my '66 into a GT because I can. It will only look like a GT but it will be better. K-code engine badge? Yep, of course it will be a 331 that will look like a K engine.
I'd rather build a restomod/GT clone out of a C-code/C4 car than restomod the real deal. I would never tell anyone that it was an actually GT though if asked. The only secret would be the engine.
Old Aug 9, 2007 | 11:13 AM
  #35
james_topless67
So to re- map:
P R ND 2 1 becomes
P R N OD D L
Thanks that is what I was looking for.
Old Aug 9, 2007 | 11:18 AM
  #36
james_topless67
Is the Granada brake conversion the way to go? I have manual drums now and would like to go to power disk/drum.
poke68
Dec 16, 2025 03:36 PM
maestro1024
Sep 21, 2015 02:40 PM
skiprCH
Oct 23, 2005 05:34 PM
MUSTANG1967GTA
Oct 2, 2005 10:14 PM
