WIRING FOR BACKUP LIGHTS
Old Aug 10, 2007 | 05:02 PM
xswoopr's Avatar
xswoopr
Default WIRING FOR BACKUP LIGHTS
Just swapped a C4 for a T5 in my '66 and I'm stumped on how to wire in the backup lights. Wiring is not my strong suit, so if anyone could describe this as you would a child please enlighten me.
Old Aug 10, 2007 | 11:32 PM
gothand's Avatar
gothand
Default RE: WIRING FOR BACKUP LIGHTS
I've done this swap on two different '65s, neither of which had backup lights. That said, I believe there are two possible connections, a set of wires with a plug on the end and the other being a fitting on the side of the transmission with two threaded studs. Grab an ohmmeter or a test light and some wire and test for continuity with the transmission in reverse. It has to be one of the two. Essentially, there is an on/off switch built into the transmission.
Ford_Dude
Sep 15, 2015 03:25 PM
jaiidutch
Sep 14, 2015 10:29 AM
cbird1177711
Sep 3, 2015 08:43 PM
amandahchase
Sep 3, 2015 10:09 AM
cbird1177711
Sep 2, 2015 08:51 PM
