door hinge repair question
Old Aug 12, 2007 | 12:00 PM
shikoz's Avatar
shikoz
Default door hinge repair question
Does anyone have a good "how to" on door hinge repair for 66 Mustang?
Old Aug 12, 2007 | 12:38 PM
66GTKFB's Avatar
66GTKFB
Default RE: door hinge repair question
I would recomend you buy a good used one and installed it. I did,then tried to fix the not-so-good one I took off using the parts included in a rebuild kit. Drive out the old hinge pin with a driftand a very large hammer on a very large bench vice. A good pair of vice grips helps too. Re-assemble hinge. For the spring, thread two pieces of 20awg safety wire thru the center of the spring a couple of times and compress the spring in a vice. Pull the safety wires, taking up any slack and twist the ends securelyto retain the spring as compressed. Putthe lower hinge in a vice, install the springand clip the safety wires.
Jim
Old Aug 12, 2007 | 12:53 PM
shikoz's Avatar
shikoz
I just bought the repair parts. It's hard to find a good set of hinges because their usually off of the car and there's no way to test them- or is there??? mustang monthly mentioned it best to re-use the old springs- would you concur?
Old Aug 12, 2007 | 01:15 PM
66GTKFB's Avatar
66GTKFB
Use the old 'open and close the door' test. There are four thing that can go wrong on a hinge: too rusty - toss it; bad pivot pin - replace it; bad roller and pin - replace them; bad spring - replace it. I got a package of 5 Ford replacement springs (NPD I think) and used all (I've got four cars). I also bead blasted the best of the used springs (some were distorted), phosphated them and have installed two in the last few years. Aftermarket springs may be junk, I don't know.
Jim
04stangman
Sep 17, 2015 01:45 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
SYNY5TER
Sep 2, 2015 01:35 AM
