Tach Wiring????
Old Aug 17, 2007 | 04:37 PM
JohnCalvin's Avatar
JohnCalvin
Default Tach Wiring????
Dropped in a newly built 302 and now i've decided i need a tach. I bought one from summit and i can't wait to get it working....
Anyone know an easy wire to tap into for 1. 12v 2. lights 3. ground...
I really have no experience with wiring and want to avoid the guess and test method!!!!
Old Aug 17, 2007 | 05:09 PM
66GTKFB's Avatar
66GTKFB
Default RE: Tach Wiring????
Follow the instructions.A switched 12V source is available on the stud on the back of the ignition switch. Put a number 10 stud ring lug on the wire, slip it over the stud and tighten a 10-32 nut over it.
Jim
Old Aug 17, 2007 | 05:20 PM
JohnCalvin's Avatar
JohnCalvin
thanks... will do... welding, cutting, maching, etc doesn't scare me in the slightest... but wiring sure makes me nervous!
Old Aug 17, 2007 | 05:28 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 66GTKFB
Jim
I find it interesting you came over to my side and not use the infamous brown wire.
Old Aug 17, 2007 | 06:56 PM
66GTKFB's Avatar
66GTKFB
Your side! This is under the dash. Brown under the hood is for the electric choke crowd - remember. Now, where would you hook up the 12V electric pop-corn popper?
JIm
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
lmurf60
Sep 24, 2015 10:07 PM
