good 289 performance heads?
Old Aug 19, 2007 | 05:10 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: good 289 performance heads?
It depends on what the rest of the engine has on it.
Old Aug 19, 2007 | 05:14 PM
SS4LUNCH's Avatar
SS4LUNCH
670 too big.
Old Aug 19, 2007 | 05:28 PM
countryboy116's Avatar
countryboy116
Soarings its a stock 289 for now, the engines in real good shape, clean and strong running but its stock. Eventually like ive said he wants to put in a new cam and heads, what would be an appopriate carb? somewhere around 600cfm? or would that still be too high?
Old Aug 19, 2007 | 05:31 PM
SS4LUNCH's Avatar
SS4LUNCH
A little big still but it will work fine and leaves room to grow without having to buy another carb.
edit- according to the CFM math formula, a 289 running up to 6500 rpm requires a 543 cfm carb.
Old Aug 19, 2007 | 05:43 PM
my77stang's Avatar
my77stang
570 street avenger or speed demon, up to a 625 road demon would be good. for him, a 570 would be best. also, a performer rpm or a weiand action plus would be even a better choice.
IMO you cant go wrong with a 598.00 pair of GT40P's. already have stiffer springs and larger valves, plus they are genuine ford castings which gives a more stock appearance and in the long run will hold up better than something aluminum.
67mustang302's Avatar
67mustang302
I'm running a 570cfm on mine, and the only stock parts are the block and crank, and I'm shifting at 6,000rpm with a roller cam. You don't need a big carb to make power. Carb size has little to do with horsepower, it's all about engine displacement, RPM and volumetric efficiency(there's that word again).
Old Aug 19, 2007 | 05:48 PM
countryboy116
Hm some good information here, I'll have to make sure he sees this, we are both still learning, i have some basic knowledge (very very basic) about these engines but im learning so thanks guys. So a 570 street avenger carb would be perfect for him with either a performer rpm or weiand action plus manifold, good to know, thanks again guys!
djbigskrilla
Sep 20, 2022 01:04 AM
Faolan65
Aug 27, 2015 06:40 AM
Faolan65
Arizona Regional Chapter
Aug 25, 2015 09:24 AM
Stilz
Aug 19, 2015 06:17 AM
ding56
Aug 14, 2015 02:40 AM
