undercoating
Old Aug 21, 2007 | 03:15 PM
  #21
dozierstang's Avatar
dozierstang
Default RE: undercoating
Rust encapsulator is good stuff. I applied part of it with a brush and also sprayed some places too. And it is less expensive than POR-15 and just as effective. The red color matches pretty close. Like I said, I had nearly 90% of the original red oxide still left on mine. I was hard to even scratch it. Once I got it cleaned, I almost just left it alone but I went an extra step. I did not sand because, well, it is the under side of the car it is going to get dirty. I also had to paint part of the underside that was noticable with semi black. Otherwise the red sticks out.
Old Aug 21, 2007 | 03:20 PM
  #22
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: JMD
ORIGINAL: Soaring
No, red oxide is like a paint. Well, actually more like a primer. It doesn't get old and crack.
Here, read about it.
http://www.international-paints.co.u...p;surfaceid=21
It will not crack unless applied too thickly.....which can be an issue when people are unfarmilliar with paint products!! There can be a mentality where if some is good, more must be better, it does not always work that way with paint/primer, etc.
Well, yeah.....I suppose you have a thin argument point there, but that stuff is not thick enough to put on too thickly. Unless you put on 5 or 6 coats. What idiot would do that?
Old Aug 21, 2007 | 03:55 PM
  #23
mySAVIOReigns's Avatar
mySAVIOReigns
okay...so how cheap is this red oxide stuff, and how does it compare to other undercoatings? Also, how easy is it to apply?
Old Aug 21, 2007 | 04:04 PM
  #24
Soaring's Avatar
Soaring
I ♥ Acer
Check out the link I gave you for a price. You just brush it on, or spray it on if you have an air pump and paint nozzle/wand. It is most effective with new steel metal, but you can clean up your existing steel and treat it with the red oxide. Ford used it at some plants, but not all. If I remember correctly the Metuchen, NJ plant did not use it, but I guess that is a moot point. It is a good product to use just like POR 15.
Old Aug 21, 2007 | 04:17 PM
  #25
JMD's Avatar
JMD
ORIGINAL: Soaring
Ummm,,,, are you sure you want to ask that question??
Old Aug 21, 2007 | 04:22 PM
  #26
JMD's Avatar
JMD
ORIGINAL: Soaring
15 years ago or so, red oxide primer could be bought at auto paint stores, I used to use it on occasion, I don't know if they still Carry it or not though....
It was a very good surfacer it sanded down nice and smooth, without lots of effort...
Old Aug 21, 2007 | 07:07 PM
  #27
rlbjrcpa's Avatar
rlbjrcpa
I have the exact problem Soaring described, the undercoating is cracking and starting to rust underneath. I removed the undercoating in a small area with some chemical stripper - not a good idea. Took a long time to setup and then didn't really work great. Starting this weekend, its a heat gun with some putty knives.
Old Aug 21, 2007 | 07:37 PM
  #28
eep4life's Avatar
eep4life
a quick qestion... my 69 coupe the bottom of my car is an off white almost tan any one know why?
guitarman376
Oct 11, 2015 01:47 AM
plcdude
Mar 1, 2008 10:07 PM
70coupe
Aug 12, 2007 08:12 PM
Bulldog66
Dec 7, 2006 11:22 PM
69Mach_1
Sep 18, 2006 03:03 AM
