t5 to 347
Old Aug 30, 2007 | 11:47 AM
JMD's Avatar
JMD
Default RE: t5 to 347
ORIGINAL: Starfury
I don't feel like having to massage my tunnel to get a TKO to clear.
The TKO 600 we put in my son's 66 fit with absolutly -0- modifications to the car......
Fit like a glove.... except not as tight as a glove, there is plenty of clearance. I did drop the trany crossmember about 1 1/2", (I think they sent the crossmember for a T-5, not a TKO) but fit, finish, and function are perfect.
Old Aug 30, 2007 | 12:04 PM
Starfury's Avatar
Starfury
That tranny crossmember drop is what saved you. Tremecs are square on top, which means they run right into the tunnel without modifications. Generally you either have to go at it with a BFH or cut a couple small strips out to clear.
Your method works...kinda. Problem is, now the pinion anglemight beoff.
Old Aug 30, 2007 | 12:13 PM
JMD's Avatar
JMD
ORIGINAL: Starfury
The pinion angle is fine, we raised the rear end of the car some so the tranny drop actually improves pinion angle, I am not a bigfan of the always going uphill look...
"Adapt and improvise,,," (Clint Eastwood - Heartbreak Ridge)
Old Aug 30, 2007 | 01:13 PM
knuckless's Avatar
knuckless
well id love to get a toploader but its $800 for a rebuilt one and then a whole lot more for everything else to put it in, so how much would it be to rebuild my C4 and have it handle 400hp 400torque
Old Aug 30, 2007 | 02:11 PM
knuckless's Avatar
knuckless
i use cjponyparts alot and they dont rebuild C4s but they sell new ones, the cheapest its $900 but is built to handle 450hp, thats a bit to pricey for me though, im going to spend almost 5k total on the engine
Old Aug 30, 2007 | 02:19 PM
JMD's Avatar
JMD
ORIGINAL: knuckless
If it includes the torque converter it is a good deal, (imo)you can figure about $200.00 for a converter no matter what route you take...
When investigating this rebuild / replacement it is important to know whether the price quote includes the converter or not.
Another option would be to use your curent C-4 untill you kill it..... (if it works)... It can be fun "killing parts"... If it works now, you should be able to make it last a while by staying out of it, when you get ready for a new one,,,,,,,, kill it....
Old Aug 30, 2007 | 02:34 PM
Starfury's Avatar
Starfury
ORIGINAL: JMD
I guess that would work
And yeah, I like the 'run it until it goes BOOM' principle Meanwhile, save up for a beefier model. Just don't listen to the people that tell you to go C6. They gobble power, weigh a ton, and a good built C4 will handle just as much power anyway.
Old Aug 30, 2007 | 03:55 PM
knuckless's Avatar
knuckless
killing it sounds fun i just didnt want to ruin my engine, the new C4 doesnt come with anything, so yea its going to be another few hundred ontop of that $900
Brett Ludlow
Sep 23, 2015 06:59 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
90GT347
Jul 19, 2004 12:36 AM
