turning signals = need help
Old Sep 2, 2007 | 03:08 PM
djsprinklesnjo's Avatar
djsprinklesnjo
Default turning signals = need help
i have a 67 fastback, the turning signals do not work at all. the hazards do not work at all either. however when i press the brake the dash turn signals light up, both at the same time and stay light untill i depress the brake. is this normal?
ive done a search but havnt found the answer. also i checked the bulbs and they work fine. ive looked as most of the wireing i can see and it looks fine. what gives?
Old Sep 2, 2007 | 04:08 PM
knuckless's Avatar
knuckless
Default RE: turning signals = need help
i have that exact same problem with my 68 coupe, hazards only go on when i break, but sometimes the turn signals work, most times they dont
Old Sep 2, 2007 | 04:24 PM
djsprinklesnjo
i dont know where to start looking. or what the problem could be. this stinks
Old Sep 2, 2007 | 04:55 PM
67 evil eleanor's Avatar
67 evil eleanor
The switch assembly can be the problen. However, check the flashers first. If bad, replace with the solid state ones. They are a few more dollars, but will work if you loose a bulb. Anyway it would'nt hurt to spend the money on one just to see if it cures the problem as it would make a good upgrade anyway when you resolve the problem. Check the plugs and grounds also.
Old Sep 2, 2007 | 04:59 PM
67mustang302's Avatar
67mustang302
Brake wiring isshorted to the turn signal/flasher wiring, or something is wired improperly
jwog666
Dec 27, 2021 08:09 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
breaking
Oct 2, 2015 01:27 PM
ChampInSD
Oct 2, 2015 04:55 AM
logan409
Sep 26, 2015 07:43 PM
