flywheel types
Old Sep 5, 2007 | 11:11 AM
kdm123's Avatar
kdm123
Default flywheel types
Hey guys,
I have a '69 302 engine that I bought with no flywheel or bellhousing. I bought at replacement '69 flywheel and the bellhousing off an '89 Mustang. Now I find that the bellhousing won't fit over the flywheel (the bellhousing is too small). So what gives....are not all Ford small-block flywheels the same diameter???
Old Sep 5, 2007 | 11:50 AM
JMD's Avatar
JMD
Default RE: flywheel types
ORIGINAL: kdm123
Hey guys,
No, they can be different.
The flywheel, starter, clutch, and bellhousingmust be more or less matched. Also, I have doubts as to whether your later bell housing will work with your early transmission.
In my opinion, your best option is to acquire an early bell housing and is associated block plate and go from there. Whatever you decide, you will have to look at the above parts as a package that you will need to assemble... The easiest approach to this would to be for you to get everything for the year and model of your car. There are certainly other approaches that can work, but they will hurt your head.....
Watch your flywheel balance as well, you will need a 28 oz imbalance for your 69 302
http://store.summitracing.com/egnsea...115+4294840126 Lots of options!!
Old Sep 5, 2007 | 12:08 PM
kdm123's Avatar
kdm123
Ok, thanks for your help. I'll have to look into getting the right parts.
Old Sep 5, 2007 | 12:24 PM
67mustang302's Avatar
67mustang302
Get a lightweight steel flywheel Just make sure it's the right balance
Old Sep 5, 2007 | 12:39 PM
JMD's Avatar
JMD
ORIGINAL: kdm123
Before I send you off on a parts buting spree, lets examine what you have!
What transmission are you running?
You might see if the tranny will actually bolt up to the bellhousing before continuing... This is not the only factorthat determines whether the housing will work, the shaft placement and clutch pivots must be determined as well,but if the tranny will bolt up, this is a start.
Old Sep 5, 2007 | 09:02 PM
kdm123's Avatar
kdm123
I'm actually not installing the engine in a car. I'm putting it on an engine testing station (http://www.northerntool.com/webapp/w...4501_200334501) I need to have a flywheel and bellhousing installed so that I can hook upa starter (and also for some measure of safety). Since the bellhousing is from an '89 Mustang 5.0, I'm going to go ahead and get a flywheel from that model. I realize the balance will be off, but I'm only going to run the engine at low RPM's on this test station. When I end up installing in a car, I'll be sure to have balanced components.
One other question: is there a backing plate between the bellhousing and the block like on cars with an auto trans?
Old Sep 5, 2007 | 11:09 PM
JMD's Avatar
JMD
ORIGINAL: kdm123
I get that catalog!
You will need a "block plate" (like an auto) in order to attach the starter.
I think that this flywheel will do what you want it to do, and it will have the correct ballance.
http://store.summitracing.com/partde...p;autoview=sku
Old Sep 6, 2007 | 10:07 AM
kdm123's Avatar
kdm123
So do I need a block plate for an '89 bellhousing then, or are the block plates a universal fit? Where can I find one?
Old Sep 6, 2007 | 10:31 AM
JMD's Avatar
JMD
ORIGINAL: kdm123
http://www.mustangsunlimited.com/ite...?T1=PA26445+01
It looks like this one will work for all SBFs, with any flywheel or bell
Old Sep 6, 2007 | 10:42 AM
kdm123's Avatar
kdm123
Ok, thank you!
2007CalSpec
Dec 13, 2020 11:42 AM
kevsgt
Oct 9, 2015 10:12 PM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
mrappe
Sep 26, 2015 10:16 AM
