monte carlo bar
Old Jan 17, 2008 | 07:13 PM
  #31
baddog671's Avatar
baddog671
Default RE: monte carlo bar
ORIGINAL: FastMustang
I also have a 69 Mustang and just got my Monte Carlo Bar (curved). I went to see if the holes matched but they didnt. I was able to get the bolts in bottom holes on the insidein with out a problem but the top ones I could not. The top part that supposed to sit flush where the two extra holesare drilled did not sit flush.
I left the car jacked up and will try tomorrow. Hopefully it lossens up. Is it necessary to loosen the 6 fender bolts on each side for extra movement? Any more advice?
Also, I didnt notice the notch. The bar did not bring one I did not notice the raise part on the Car. Will I have to cut a notch on the bar? or like another member said, cut the bottom half?
Thanks
Ruben
If need be, use tough lovin to get that bar in there. I got one side in and bolted it, thenused a rubber mallet to beat the other side down in.
Here, I think this picture will help you. Here you can see the "hump" and how I docked the lowerhalf off to clear it. Simple enough....
Old Jan 17, 2008 | 07:32 PM
  #32
BULLITT GT 390's Avatar
BULLITT GT 390
yes Get it you need it heres a photo of mine I had to weld the side bolt holes because the bolts did not line up and redrill them to fit and it fits good now!!! I bot mine at mustangs unlimited
good luck
[IMG]local://upfiles/63181/CE7CAB3C9D60480388D3E89BEF191CD5.jpg[/IMG]
Old Jan 18, 2008 | 05:10 PM
  #33
mustdoc's Avatar
mustdoc
Quick questions:
Is it recommended to replace the stock export braces with a one-piece brace?
I have A/C - does that prevent a monte carlo bar from being installed or is there a work-around?
Old May 15, 2008 | 05:57 PM
  #34
cfd2bc's Avatar
cfd2bc
I have a 66 and it has been sitting without the engine in it for some time. I bought it that way. I am getting ready to drop in the motor and am not sure if the motor mounts will line up. I think the shock towers have moved in about 1 inch. Would it be possible for one of you guys with the brace to get me a measurement of the brace from one side to the other.How big an opening will I need to drop the thing in? I have ordered a bar and am in the process of "stretching" it back into place very slowly. Thanks, Jeff
Old May 15, 2008 | 07:52 PM
  #35
hutchamatic's Avatar
hutchamatic
Made my own.
Old May 15, 2008 | 09:02 PM
  #36
racin66coupe's Avatar
racin66coupe
HOLY OLD POST BATMAN!!!!
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
fastbackford351
Oct 1, 2015 12:24 PM
winner99
Oct 1, 2015 10:52 AM
fastbackford351
Sep 12, 2015 09:42 AM
