steering problem.
Old Sep 8, 2007 | 02:23 AM
xian67's Avatar
xian67
Default steering problem.
its wierd. i cant really turn my steering wheel. i cant makea U turn because i cant turn it alot. i had a really messed up power steering pump so i bought a new one today and put it on and its still the same. any ideas?
Old Sep 8, 2007 | 10:58 AM
knuckless's Avatar
knuckless
Default RE: steering problem.
does the power steering have a belt on it? any power steering fluid?
Old Sep 8, 2007 | 11:37 AM
xian67's Avatar
xian67
yes and yes
Old Sep 8, 2007 | 12:11 PM
valley firearms's Avatar
valley firearms
Check you gear box and make sure the arm is not hitting anything. Check it while someone is sitting in the car and turning the wheel back and forth. From there check and see if anything is bent or mis adjusted in your front end.
[align=left] [/align]
Old Sep 16, 2007 | 02:01 AM
xian67's Avatar
xian67
i was talking to some mechanic and he said its probably my "ram arm"
Is this what he ment?
http://www.mustangdepot.com/OnLineCa...m_cylinder.htm
Old Sep 16, 2007 | 11:51 AM
Gun Jam's Avatar
Gun Jam
Yeah I think thats what he is talking about.
I have never heard of one actually jamming up before. If your power steering pump was totally shot you should still be able to turn the wheel from full left to full right........It will take much more effort but should not jam up.
Gun
Old Sep 17, 2007 | 07:41 AM
dnswwood's Avatar
dnswwood
Do you have headers on the car? I remember reading a post on here about needing a "drop" bracket for the power steering if you had headers on the car.Seems the headers keep the ram from fully opening and closing.
Hope this helps ..
Jeff
Old Sep 17, 2007 | 08:46 AM
xian67's Avatar
xian67
not yet. i just have the stock manifolds.
ok so my dads friend came over and he tuned my carb and he said i needed a bigger rack and pinion =(.
dont those cost around 1,000?
lincolnshibuya
Dec 8, 2020 01:49 PM
CS2007
Jun 25, 2019 09:45 PM
ChampInSD
Oct 2, 2015 04:55 AM
allenmaty
Sep 24, 2015 09:17 AM
stark777
Sep 21, 2015 12:46 PM
