carbeurator
Old Sep 13, 2007 | 12:52 AM
68SCode4speed's Avatar
68SCode4speed
Default RE: carbeurator
Autolite 4100 Spreadbore from Pony Carbs (It's on a mildly warmed up 289)
Old Sep 13, 2007 | 12:55 AM
67mustang302's Avatar
67mustang302
I'm running the 570 Street Avenger on mine, got it tuned nicely, just need to fine tune the accelerator pump, just another squirter change or 2 I hope. My next carb will be a Pro Systems blow-through. The 570 is easy to tune though, I like it
Old Sep 13, 2007 | 01:01 AM
ky's Avatar
ky
America ftw
does the street avenger have this problem: when i shut my car off the carb still dumps fuel into the manifold. my floats are messes up. since it dumps too much fuel, it doesnt want to start back up when the engine is warm. does the street avenger have this problem?
Old Sep 13, 2007 | 01:32 AM
67mustang302
No, it does not. That sounds like a blown power valve, gravity draining into the manifold
Old Sep 13, 2007 | 06:59 AM
RobbieG.'s Avatar
RobbieG.
I go Holly all the way. Easy to tune,cheap to rebuild.
Old Sep 13, 2007 | 10:19 AM
NorCalTroy's Avatar
NorCalTroy
ORIGINAL: Starfury
There is no "best" overall carb. If you want something to slap on a stock or mild small block, an Autolite 4100 is hard to beat. If you need more tuneability but don't want to be finicking with it all the time, Edelbrocks arevery easy to tune. For the most tuneability (at the cost of some reliability) the Holley design is probably better. I've heard that Barry Grant carbs(which use a Holley deisng)are amazing, but more expensive.
Well said Starfury.
I think any answer to this question will be based on personal opinion more than anything else. I have an Edelbrock and have had absolutely no problems with it, but others have had the exact opposite results with the same carb. There are several existing threads here that discuss both the pros and cons of just about every carb manufactured. Do a quick search and settle in for a lot of reading.
Good luck, let us know what you decide on.
Old Sep 13, 2007 | 11:21 AM
Gary H's Avatar
Gary H
ORIGINAL: true66gt
Needle valve's are dirty, power valve is bad or to much fuel pressure. Save the money and just fix what you have. A rebuild kit is alot cheaper than a new carb.
Old Sep 13, 2007 | 11:51 AM
jspagna1's Avatar
jspagna1
I'm running a Holley 650 DP with manual choke. Depending on the size and how built your motor is I have only heard good things about the Street Avenger 570.
Old Sep 13, 2007 | 12:04 PM
67mustang302
I think Holley has under rated the 570, they must have tested it with a low depression. But yeah, the "best" carburetor really depends on the setup, what's good for one is rarely good for all.
kevlong2
Jun 12, 2013 09:52 AM
Guinnessfox
4 Cylinder NA and Turbo
Sep 22, 2011 06:29 AM
Junior OTard
Sep 12, 2008 11:19 AM
DriftingRz
Feb 24, 2008 09:28 AM
72MachOne99GT
Jul 16, 2007 02:24 PM
