engine combo question 289
Old Sep 19, 2007 | 08:32 PM
bm22's Avatar
bm22
Default engine combo question 289
well thanks for your help on the other questions, now i have another one
i found a 289 block would a
edelbrock 2091
http://store.summitracing.com/partde...mp;appfilter=1
and a Holley Model 4160 Adjustable Float Carburetors
Carburetor, Model 4160, 750 cfm, Square Bore, 4-Barrel
http://store.summitracing.com/partde...p;autoview=sku
would this work. how much hp could i expect from a 289 with this setup. also is there anything better in this price range i should look at.
thanks again, this is just one of many more question i am going to ask you guys, i hope you'll don't mind
Old Sep 19, 2007 | 09:08 PM
Starfury's Avatar
Starfury
Default RE: engine combo question 289
A 750 carb is WAY too big for 289. That top end kit is solid, but you need to be looking at a ~600CFM carb, not a 750.
Old Sep 19, 2007 | 09:55 PM
bm22's Avatar
bm22
ok thanks
Old Sep 20, 2007 | 12:37 AM
Mr. Classic EFI's Avatar
Mr. Classic EFI
Those 60cc heads are going to lower your compression ratio. 58's would be better, but you'll still need pistons to keep or better the stock 289's comp ratio.
Old Sep 20, 2007 | 01:16 AM
67mustang302's Avatar
67mustang302
Those heads, cam and intake will also let way more air into the cylinder, so even if the CR is down a bit the actual compression and combustion pressure will be higher. Also try to keep the CR down if you plan on a blower later on down the road
Old Sep 20, 2007 | 05:42 AM
fast66's Avatar
fast66
ORIGINAL: 67mustang302
Don't want to disagree with you again, but Valve overlap will actually reduce the dynamic compression ratio. ie the main reason you can run much higher comp on big cams. As Mr Classic says, you will want higher compression pistons to raise that ratio.
Old Sep 20, 2007 | 10:45 AM
Starfury's Avatar
Starfury
True, but it's still going to be more of a performance gain due to flow than he'll lose from compression.
kdryan
Aug 21, 2015 04:01 PM
ding56
Aug 14, 2015 02:40 AM
classic69FB
Aug 12, 2015 11:58 PM
HIS S-197
Aug 10, 2015 05:47 PM
