50oz flywheel and toploader
Old Sep 27, 2007 | 12:25 AM
valley firearms's Avatar
valley firearms
Default 50oz flywheel and toploader
My 87 347 came with a 50oz damper and flywheel. I will be using a Centerforce clutch and pressure plate. I know those will work with the toploader as far as splines. Has anyone used a late model 50oz flywheel with an older toploader? Should I be able to use my old starter? I was told the old starter may still work.
[align=left] [/align]
Old Sep 27, 2007 | 03:27 AM
gothand's Avatar
gothand
Default RE: 50oz flywheel and toploader
Should not be a problem. Both are likely 157 tooth and will line right up with the starter.
Old Sep 27, 2007 | 11:34 AM
67mustang302's Avatar
67mustang302
They're both 147 tooth, the difference is the later flywheels are setup for 10 or 10.5" clutches, the early are only setup for 10"
6bangr
Feb 15, 2016 07:40 AM
junior04
Sep 28, 2015 10:53 AM
dudeguy421
Sep 24, 2015 11:16 AM
ccdguy
Sep 19, 2015 05:20 PM
ponyride00
Aug 12, 2015 01:57 PM
