strange tapping from engine near transmission
Old Sep 29, 2007 | 08:34 PM
cubby67's Avatar
cubby67
Default strange tapping from engine near transmission
i recently put a new clutch in, and now i have a strange tapping sound coming from the motor. i thought at first it was because i took off the exaust pipes. now they are back on and it is still there. i started the motor( 6cyl. 200, with three speed manual) and pressed on the oil pan and it changed the noise. did i not line the clutch up right? please help i need this car to work.
Old Sep 29, 2007 | 10:50 PM
JMD's Avatar
JMD
Default RE: strange tapping from engine near transmission
Are you certain that you installed the clutch disk the right way out?
I have seen this done more than once!!
This can cause things to be noisy....
Other than that I assume you put the same bolts back into the flywheel... if bolts are too long they can sometimes strike things where they stick through the flywheel....
And, it could be coincidence, and you might be having another issue separate from the clutch,,,, but I really doubt it... you may just need to re-do the clutch..... and yes, re-do's suck.....
Welcome to the Forum Cubby!!!!
Old Sep 29, 2007 | 11:11 PM
valley firearms's Avatar
valley firearms
It's CUBBY, CUBBY!
[align=left] [/align]
Old Sep 29, 2007 | 11:17 PM
JMD's Avatar
JMD
ORIGINAL: valley firearms
It's CUBBY, CUBBY!
[align=left][/align]
Thanks Mike,, I kind of butchered that welcome didn't I?
Damn,,, I must have been thinking about myself when I posted......
Sorry Cubby...
CMcNam
Oct 30, 2022 11:40 PM
Granatelli Sales
Jan 20, 2020 12:34 AM
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
MustangVixenGT
Sep 16, 2015 04:16 PM
