rockers and push rods
Old Oct 9, 2007 | 02:37 AM
eep4life's Avatar
eep4life
Default RE: rockers and push rods
thats ok... i mean im really just looking for some stock replacements.. or some thing along those lines... eventually i plan on upgrading the heads so there no point in fixing these up to much... there already ported and resurfaced.. thats good enough for now... so what type of rockers do i need and where can i get them?
Old Oct 9, 2007 | 03:02 AM
67mustang302's Avatar
67mustang302
If you're just gonna get better heads later one, then just go with stock rockers. Or you could setup those heads for 3/8" studs and when you get better heads later you'll already have the necessary studs
Old Oct 9, 2007 | 10:37 AM
eep4life's Avatar
eep4life
sounds good... but where can i get stock rockers? ive been looking but no luck... any one have any links...
Old Oct 9, 2007 | 10:44 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
ORIGIONAL: my77stang
if the heads are stock from 69
yeah stang has personal experience with this engine......all 5k pieces of it....
Old Oct 9, 2007 | 07:25 PM
eep4life's Avatar
eep4life
i think the rockers i have are the wrong size/style how could i tell
Old Oct 9, 2007 | 11:09 PM
eep4life's Avatar
eep4life
the rockers i have... the bearing or what ever that think that fits inside the rocker is... is like a half circle.... any ways.. that piece... the hole that the stud goes threw is wide enough to fit around the base of the stud.. is that ok or is it the wrong type of rocker/bearing..
as these photos show.. that bearing can side all the way down.... basically i just need to know how to tell if the rockers i have are wrong for the heads.. you can also see the rockers in the back have been torqued down.. does it look right... i really dont know
Old Oct 11, 2007 | 05:46 PM
eep4life's Avatar
eep4life
can any one help me.... with this rocker question... if you need more info let me know and ill see if i can get it.... basically i just need to know if the rockers i have are ok to use....
Old Oct 11, 2007 | 10:30 PM
Colorado_Mustang's Avatar
Colorado_Mustang
That is the correct fulcrum bearing. You don't want the rocker riding on the threaded part of the stud as it will break.
Sixer4Life
Oct 12, 2015 04:26 AM
Bokeo
Oct 10, 2015 08:28 PM
jrrhd73must
Oct 2, 2015 09:17 PM
UrS4
Sep 30, 2015 10:13 AM
Sixer4Life
Sep 28, 2015 07:05 AM
