Need conformation
Old Oct 10, 2007 | 12:54 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default Need conformation
Measurement
Ford 8.8" Width between wheel mounting surfaces
59.75" Pinion offset to right of center
2-3/16" Pinion length, tube center to U-joint center
11-5/8" Pinion height, U-joint center below tube center
1-7/8" Diff cover distance behind tube center
4-3/4" Bottom of diff housing below tube center
5-7/8" Disc brake rotors
11.25 x 7/16" Drum brake shoes
7.25 x 1.25" (e-brake) Distance between spring perches (o/c)
39-1/4" Tube diameter
3.25" (neck down to 2.75") Axle shaft diameter
1.31" 31-spline Clearance under diff w/33x9.50 BFG MT's
9-3/8" Shock eye below tube bottom
flush Shock length at rest
20" Remaining shock compression at rest
4"
could someone give me a confermation between these two, im looking at putting an explorer rear in the 67, so i would like to make sure this info is correct.
Old Oct 10, 2007 | 01:41 PM
JMD's Avatar
JMD
Default RE: Need conformation
I don't know enough specs to be of much help, but I can say that an offset pinion will cause issues with many aftermarket exhaust systems,,, the exhaust on my son's 66 is pretty damn close to the driveshaft.
This issue could be overcome easily enough, but you should be aware of this possible complication....
Which brings to mind that an offset pinion will not fit into the driveshaft tunnel at the rear anyway, not so easy to overcome...
Old Oct 10, 2007 | 02:03 PM
USMCrebel's Avatar
USMCrebel
ok, well i aint bagning any metal on my stang, so ill just have a local shop build me one.
If anyone has the length of the axle ****, let me knwo, im tired of looking through countless webpages with useless info on the lengths of those.
Luke@tirerack
Wheels & Tires
Oct 27, 2012 03:17 PM
Luke@tirerack
Wheels & Tires
Sep 26, 2011 07:16 PM
JC316
May 14, 2009 09:27 PM
xX98StallionXx
Apr 30, 2007 03:39 AM
Dan@W.I.R
Nov 21, 2006 08:12 PM
