Where do I start ?
Old Oct 21, 2007 | 07:50 PM
6marc5's Avatar
6marc5
Default Where do I start ?
Hello,first all I have a '65 convertible. Unfortunatley,most of the structural metal is holey or rotted. My first task is torque boxes,inner/outer rockers and a full floor pan. I guess I am asking a what came first the chicken or the egg type question. Where doI begin and how should I go about bracing the car to keep it together?Any of you guys that have done any of the above on your cars feel free to enlighten me.
Thanks in advance,
Marc
Old Oct 21, 2007 | 08:07 PM
remicks's Avatar
remicks
Default RE: Where do I start ?
Find a rotisserie. A good one will keep your car straight while you remove bad structural metal. There are a few people on the site that built their own rotisserie for cheap, I'm sure they would help you out with a templet. Just do a search for rotisserie.
Old Oct 21, 2007 | 08:30 PM
6marc5's Avatar
6marc5
ORIGINAL: remicks
Mustanglover66 was nice enough to forward the plans to the rotis he built. How cool was that?!
Old Oct 21, 2007 | 09:05 PM
DanK69RustangVert's Avatar
DanK69RustangVert
I don't know... On my '69 Conv. I am choosing to build a frame jig rather than go with a rotisserie. The rotisserie will hold the ends, but the car is still holding it's own weight. I am concerned about the car sagging due to truly rotten frame rails and very little to bolt to. I suppose it depends on howrotten and holey that structural metal is, but let a convertible sag in the middle and you have a real problem getting anything to fit.
Old Oct 21, 2007 | 09:11 PM
6marc5's Avatar
6marc5
ORIGINAL: DanK69RustangVert
I'm lucky , my car isn't sagging at all.......yet. I'm going to weld up a jig for the door opening using the door hinge holes. that should keep it in place. I'm more questionable on where to start first. I guess just R&R one piece at a time. Start at the rockers,then the torque boxes,ect.
Old Oct 21, 2007 | 11:44 PM
mustanglover66's Avatar
mustanglover66
I am about to do pretty much the same repairs what I am thinking is do the frame rails first then add subframe connectors move to the floor pan from there and do the rockers last. bracing the door opening is a must.
Old Oct 22, 2007 | 06:06 AM
andrewmp6's Avatar
andrewmp6
Start with the frame rails make sure there good straight and not holely then work your way up keep everything level.
Old Oct 22, 2007 | 12:04 PM
remicks's Avatar
remicks
ORIGINAL: 6marc5
ORIGINAL: remicks
That was pretty cool of Mustanglover66 and quick.
Old Oct 22, 2007 | 12:49 PM
6marc5's Avatar
6marc5
ORIGINAL: mustanglover66
Hey,thanks again for the rotis plans. That makes pretty good sense,get a solid foundation and go up from there. I have to think of it as a construction site. Good idea.
Old Oct 22, 2007 | 12:50 PM
6marc5's Avatar
6marc5
ORIGINAL: andrewmp6
Thanks for the advice, all ideas are welcome here.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
dalefrancis88
Sep 11, 2015 07:15 AM
5.0 kevo
Sep 3, 2015 06:24 PM
