hp estimates? help a noob!
Old Oct 22, 2007 | 09:55 PM
dirtydave289's Avatar
dirtydave289
Default hp estimates? help a noob!
I have a 66 c code 289
headers with 2.5" pipes all the way
4 barrel holley
mild cam
bored .030 over
a few other small things..don't count those [8D]
with those listed, what horse power would you estimate im running at?
a stock '66 c code - 200hp & 282 torque
another question - what was the difference between the c code and the k code besides the 4 barrel carb?
Old Oct 22, 2007 | 09:57 PM
Hawkins 812's Avatar
Hawkins 812
Default RE: hp estimates? help a noob!
Id say approx 245 rwhp. I dont know much about the different codes beside the "k" code was alot more rare. Im sure someone will chime in and elaborate.
Hope this helps!
-Hawkins
Old Oct 22, 2007 | 10:03 PM
dirtydave289
yeah i've been trying to look things up...and i found out the k-codes were Hi-Po
k codes had four barrels
and so did the code between c and k
can't find the differences though.
anyhow, thanks a ton for posting!
245rwhp...good/bad/mediocre for a 2800lb car?
Old Oct 22, 2007 | 10:12 PM
fast66's Avatar
fast66
Sorry to burst your bubble, but with your combo, you will be putting down no more than 190 rwhp. the 200hp is a figment of fords 1966advertising imagination.
I have much the same and thats where I am.
As for the K code. there is a website which lists absolutley everything. I can't think of it off the top of my head, but if you do a google search you will find it.
I believe heads were essentially the same, but they had a different cam, different exhaust manifolds, duel point dizzy, different harmonic balancer and a few other things.
Old Oct 22, 2007 | 10:14 PM
dirtydave289
ah well there's always room for improvement lol
195rwhp...you said you had similar? still pack a punch?
I'm going hunting for that website
Old Oct 22, 2007 | 10:22 PM
Hawkins 812
ORIGINAL: fast66
I find that VERY hard to believe. Ford was actually modest when it came to rating their engines. I cant argue with someone who has the same setup, but it dont seem right to me [&:].
fast66's Avatar
fast66
Its by no means a rocket ship. But with the 3.25 gears can creep into the 14s. To get any serois power, you need to go with aftermarket heads, and higher compression. thus allowing a bigger cam.
Stroking is also always a quick way to make good power.
If you are thinkingof building your 289 to K code spec to get some more grunt, dont bother. You esentially will be putting out close toK code power now.
K codes after all were still a budget motor. Aftermarket parts are far far superior to anything that Ford put on these 40 years ago.
I would also recommend you change your dizzy over to electronic if you havent already done so.
Old Oct 22, 2007 | 10:27 PM
connor90's Avatar
connor90
yeah...id say you have about 200 rwhp, no way you have 245 with what you have
dirtydave289
Hm..I seriously am a noob, and I don't exactly know what gears i have, or heads
i know i have some '69 302 heads in my shed that the PO gave me with the car, along with another tranny and torque converter etc.
thanks for the help so far fast66, hawkins, and connor
for anyone who cares, there she is..sloppy wires, i know, dont make fun of me
Old Oct 22, 2007 | 10:41 PM
Hawkins 812
Looks mighty perty. Between you and me, she has more than 200hp at the wheels .
