Fuel Problems (pump)?
Old Oct 26, 2007 | 02:11 PM
JERM_1967stang's Avatar
JERM_1967stang
Default Fuel Problems (pump)?
Well my car starts fine.... i can drive it for about 100 feet and then it starts to die out like it is out of gas. I have over 7/8 of a tank. could the gas be stail. Could the Carb be bad or my feul pump and regulator be bad. i dont want to replace what i dont have to.
Old Oct 26, 2007 | 02:50 PM
Gun Jam's Avatar
Gun Jam
Default RE: Fuel Problems (pump)?
How old is the fuel?
Add a clear fuel filter inline just before the carb so you can see if there is any fuel in the filter when it dies.
Remove the fuel line from the carb and point the open end into a cup, have someone crank the engine over and see how long it takes to dump say 8oz into the cup. It should dump 8oz of fuel in under 10 sec just by cranking the engine (no start)
All very cheep test to help find the problem. until you run some of these test there is no way to identify a problem child (it could be anything).
-Gun
Old Oct 26, 2007 | 05:05 PM
jlg2002's Avatar
jlg2002
9 of 10 fuel problems are electrical. meaning when's the last time you tuned up your car.
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 08:51 PM
SYNY5TER
Sep 2, 2015 01:35 AM
