Pertronix and ballast resistor help
If you've done the ignition resistor bypass, then yes. With 12V feeding the Pertronix and a 40kV coil, you'll have enough voltage to open up the plug gap to .040" or so.
I just installed the Pertronix ignitor and Flamethrower coil in my son's 67. According to the installation instructions that came with the coil, I need to remove the ballast resistor when I install this (1.5 ohm) coil on an 8 cyl. engine. I'm getting about 6.5 volts at the coil which indicates a resistor of some sort is present. Reading through other threads I foundout mycar hasa pink resistance wire. How do I bypass this wire? Does one end of this existing pink wire connect to the + terminal of the coil, and the other end is at the ignition switch? If so, I guess I would just remove that pink wire, run a new wire from the coil, through the firewall, to the ignition switch, right? I just want to make sure I'm doing the right thing before I start messing with the ignition switch. The car starts and runs the way it's hooked up now with the resistor wire, but I guess it would run better if it were getting a full 12 volts to the ignitor. Is it a big deal getting to the ignition switch? I know Soaring said it was a piece of cake, but he know's what he's doing, and I hate electrical work.
Here are the other threads I've read about ballast resistors. I'm just getting confused with all the ways to bypass the resistor.
https://mustangforums.com/m_2679523/tm.htm
https://mustangforums.com/m_3496349/tm.htm
Any help would be appreciated: What wire gauge to use to bypass, how to open the ignition switch and which wire on the switch to bypass.
Hey! I am aware that this thread is rather old, but I am just now facing this same issue. I can't seem to find a simple answer on this pink resistor wire. I am running a brand new summit racing RTR distributor and summit racing coil. The new dizzy needs the constant 12v, do you think you could give me the instructions on how to run a new wire from the ignition to the coil. I am pretty new to this so I am trying to learn. Also what kind of "new" wire do I need? What gauge?
Since they are usually PINK, this wire is easily traceable, running from the ignition switch to the coil. Simplest way to eliminate it is to just add a common, insulated copper wire running along with it, in parallel. The new wire may be connected at the ignition switch, same terminal as the pink, in the car, and the other end connected to the coil terminal along with the old pink one; you need not remove the pink wire at all. The effect electrically of paralleling the two is virtually the same as removing the pink and adding the fresh new wire. Use wire having high-temperature rated insulation; it gets HOT under hood. Insulation type THHN/THWN is ideal, having a nylon outer wrap. Size the wire sensibly, #16 AWG is big enough to carry 10 amps. I would go no SMALLER than # 18. If leaving the pink wire in place makes you "squirrely", go ahead and remove it.
wonso79
Apr 1, 2011 11:12 AM
