Our backwards resto....66 vert!
Old Aug 27, 2008 | 08:34 PM
  #251
wumarshall82's Avatar
wumarshall82
Jamie,
Did the fenders and door shell that you bought match up pretty well with the lines and spacing? I am thinking about replacing my fenders and door shells...
Old Aug 27, 2008 | 08:40 PM
  #252
my77stang's Avatar
my77stang
so are you keeping it now?
i cant believe you still had engine trouble after all that work. what was the last method you used when putting those plugs in?
i'd friggen weld em in before i woulda bought another motor LOL
Old Aug 27, 2008 | 09:33 PM
  #253
jamieNerikas66stang's Avatar
jamieNerikas66stang
you can see the lines from the door and the fender in the pics,...my friend has a 100% stock original untouched 67, and i think the gaps on my repo stuff are better then his OEM gaps,...i was super supprised at how well these lined up,...
my last method was to retap the hole, clean hole out with alcohol, acetone and wire brush pipe cleaner,...install new plug with JB weld on threads, and JB weld around the plug and block,..and it didnt hold for more then 30 minutes run time,...
i got this block at a great deal, so if this works, i will keep the car, if it doesnt, the car will be sold...i can not go through this all over again
Old Aug 28, 2008 | 12:14 AM
  #254
valley firearms's Avatar
valley firearms
If you are worried, I would seriously see about getting the engine running outside the car. Make a engine stand or take it to the dyno. That is if you haven't already put it back in.
Old Aug 28, 2008 | 05:14 AM
  #255
jamieNerikas66stang
i mean if you have went through what i have went through in the last two months, wouldnt you be worried?
we are thinking of rigging something up so that it can be run out of the car first,..the only problem right now we are having is where to get a extra bellhousing...
Old Aug 28, 2008 | 08:44 AM
  #256
my77stang's Avatar
my77stang
honestly i would have jb'd the threads after the first or second time it leaked, and after that i would have screwed the plugs in then ran a small mig weld bead around them to make sure they NEVER leaked LOL
its cool that the car is getting a 289 though, i like them better than a 302
btw, all that money in those heads and whatnot and you ended up with cast rocker arms? how the hell did that work?
crane energizer full rollers are less than 200 bucks and i think a worthy investment.
just food for thought
Old Aug 28, 2008 | 09:55 AM
  #257
jamieNerikas66stang
they came with the original motor, i will be swapping them out after the car is up and running,..
to my knowledge you can not weld cast iron...or i would have done that the first time
Old Aug 28, 2008 | 05:51 PM
  #258
jamieNerikas66stang
its funny, i actually look like i know what i am doing, hahah
well here it is all complete, timing cover back on, oil pan, balancer, water pump, dip stick, coil, crank pulley, fuel pump, oil pressure sender...
it sure looks ****ing pretty, i just hope it runs as good as it looks,..
Old Aug 28, 2008 | 08:21 PM
  #259
my77stang's Avatar
my77stang
actually i know for a fact you can weld cast iron with a stick and the right rods... dunno what kinda sire you would need in a mig gun though.
we've welded a few blocks up with a stick that had things like cracked starter mounts or bellhousing bolt ears... things of that nature
Old Aug 28, 2008 | 08:43 PM
  #260
Joe67's Avatar
Joe67
Banned
they actually dont make a cast wire for mig =/
and what happens when your plugs go bad?
