Temp Gauge
Old Nov 1, 2007 | 07:13 AM
krobillard's Avatar
krobillard
Default Temp Gauge
I bought a new mechancial temp gauge, can someone please tell me were I can install it on the engine. My orginial temp gauge is on the intake, thenew guages inletwill not fit in that small hole. An will an oil mechanical guage fit were the orginial oil guageis? ( by the fuel pump)
1965 -302 block 289 heads 4bl
Thanks,
Old Nov 1, 2007 | 07:59 AM
dozierstang's Avatar
dozierstang
Default RE: Temp Gauge
Why are you going mechanical and not electrical? Just curious.
Old Nov 1, 2007 | 08:03 AM
superdavid's Avatar
superdavid
I have an Edelbrock (sp?) intake, and it has multiple ports for temp guages. I just backed out one of the plugs and installed the probe. It gets a much more accurate reading than an electical guage. Same thing with oil pressure: there's a splitter on the stem that the stock guage ran from, so I have both the stock electrical guage and a mechanical unit running simultaneously.
Old Nov 1, 2007 | 08:06 AM
smittycm's Avatar
smittycm
Buy anadapter. You should be able to go to Napa Auto Parts or somewhere similar and pick up a 5/8" to 3/8" adapter (or other sizes to apply to your application). Heres something I found on JCWhitney.com
http://www.jcwhitney.com/autoparts/P...002115/c-10101
Call around to your local hardware shop. I believe the correct water temp size for your application is a 3/8" NPT. Yes a mechanical oil gauge will fit. You just have to buy the right size, or get an adapter. I believe the correct size oil gauge sending unit for you is a 5/8". Don't quote me on that. Someone correct me if I'm wrong.
Old Nov 1, 2007 | 11:26 AM
Starfury's Avatar
Starfury
Yeah, you just need a pipe threaded bushing. Easy find at any hardware store, and many Napa stores will have it as well.
jwog666
Dec 27, 2021 08:09 PM
andrew1969
16
Jan 8, 2016 02:48 PM
SteelerNation82
Sep 16, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
