vinyl top question
Old Nov 13, 2007 | 08:15 PM
blozoya's Avatar
blozoya
Default vinyl top question
hi there. well im not the best when it comes to cars and was wondering if i should replace the vinyl top on my 67' mustang. Its an old car thats been sitting in my garage for centuries and have decided to restore it. Well ive already made the decision that i want a new vinyl top because my old one is torn and full of holes. This is not a convertable either and the hard top under is rusted. A few friends told me I cant replace the vinyl top because the hard top is rusted. is this true or should i just go through with it? thanks soo much.
Old Nov 13, 2007 | 09:12 PM
dirtydave289's Avatar
dirtydave289
Default RE: vinyl top question
Can't you just clean up the hard top?
Old Nov 13, 2007 | 09:17 PM
blozoya's Avatar
blozoya
its rusted pretty bad. what do you mean? i cant exactly water it down...haha. oh and thanks for taking the time to answer.
Old Nov 13, 2007 | 09:37 PM
dirtydave289
Pretty bad as in holes?
Old Nov 13, 2007 | 09:51 PM
blozoya's Avatar
blozoya
from what ive seen no but the paint that was on the top has been eaten by the rust. but i havent taken it off yet. im just looking at the parts of the vinyl that have peeled off. lets just say there are no holes, would i be able to sand it sown or something?
Old Nov 13, 2007 | 09:52 PM
remicks's Avatar
remicks
The problem with the vinyl top is that it traps moisture between it and the metal which causes the rust you see. You cannot just put another vinyl top over the rust, that will only compound the problem. Your roof will completely rot out, the car's structure will be in jeopardy, the vinyl top will be ruined from the inside out. What you need to do is if you want to put a new one on is clean up that rust and prime and seal the metal to prevent future water from seeping in. If it has holes, uh oh, get out the welder and hopefully it isn't so bad that you can't patch it.
Old Nov 13, 2007 | 09:53 PM
remicks's Avatar
remicks
ORIGINAL: blozoya
Yes you can sand off the rust and hopefully it will just turn out to be surface rust. I get to go through the same thing as you this winter. I'm taking off the vinyl top on my 67 and hopefully its clean underneath.
Old Nov 16, 2007 | 10:29 PM
blozoya's Avatar
blozoya
thanks, you are awsome times 1000. oh and good luck with that haha.
Tivo304
Aug 28, 2023 12:19 PM
04stangman
Sep 17, 2015 01:45 PM
96stang3.8
Sep 10, 2015 06:42 AM
