same problems 3 months later
Old Dec 14, 2007 | 07:22 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default same problems 3 months later
ok i think this is my tranny, but im gonna pick up a free c-4 pretty soon, i just need some other opinions
ok a while back i was having problems with getting started moving, no idea why still, but then it went away, and i cant back up even a small hill, and my engine begins to stall out and die. now it had no problem with this when i first got the car, it would back out and drive perfectly, then i started changing stuff IE motor, c5 tranny. im almost certian its my tranny not putting power to the wheels. please put you opinions on what it could be if you think its something diffrent.
Old Dec 14, 2007 | 08:27 PM
cmanf's Avatar
cmanf
Default RE: same problems 3 months later
Tough one could be a few things,
linkage not adjusted so it only goes part way in reverse.
Slipping worn out torque converter.
Low fluid level or burnt clutches in the trans new one would fix that.
Does it idle ok in park then sputter when its in gear?
Vacuum leak maybe/
I havent had a auto in a stang in years the last problem I had with one was changed the old fluid and it quit pulling.
LOL all the friction for the disc was in the fluid.
More guys will chime in that know more than I do.
Old Dec 14, 2007 | 08:56 PM
USMCrebel's Avatar
USMCrebel
ORIGINAL: cmanf
linkage not adjusted so it only goes part way in reverse.---it goes into reverse, its like theres no tq in reverse though
Slipping worn out torque converter.----probably
Low fluid level or burnt clutches in the trans new one would fix that.----filled it a month ago
Does it idle ok in park then sputter when its in gear?-----it sounds nasty in park....nice and lopey
Vacuum leak maybe/--- new vacuum hoses
thanks for the help
Nick Oliver
Oct 17, 2018 04:22 AM
Dragonus18
Sep 9, 2015 01:21 AM
zanemoseley
Sep 6, 2015 12:58 PM
zachary1988
Sep 4, 2015 03:04 PM
5.0 kevo
Sep 3, 2015 06:24 PM
