1" drop in front of I-6 '66
What I plan on doing is using a mideye leaf spring (V-8 obviously) in the rear of the Mustang. I do know that if I use V-8 springs in the front, I will practically be pointing up at the sky. My plan is to (hopefully) use V-8 springs in the front, but doing a 1" drop. (I am not fond of cutting V-8 springs)
Are there any realistic options for me to drop the front end while keeping the stock (v-8) spring length?
The difference in ride height between a stock 8 and 6 cylinder spring is about an inch, correct?
My goal is to have stiffer sprigns in the front of the car. If anyone knows of performance inline 6 springs, I can safe a lot of hassle >_<
1966 Coupe 200 ci c4
RE: 1" drop in front of I-6 '66
ORIGINAL: 90LX2.3
Im pretty sure instead of cutting the springs you can use a torch to heat them and then compress them to the desired height.
[sm=badidea.gif][sm=badidea.gif]no bad idea it can make the springs brittle and alter the spring rate disproportionately creating adverse handling conditions. cutting springs also isnt suggested but sometimes its the only way.
LivingInThePast
09-16-2015 12:20 PM
zanemoseley
09-06-2015 12:58 PM
