Convert to 5-lug
Old Jan 5, 2008 | 09:11 PM
musting's Avatar
musting
Default RE: Convert to 5-lug
ORIGINAL: 66FastbackGT_T5
Hi, Musting
Its just because i want go discbrake in the front and there i only find 5bolt
Also you find no nice 4Bolt wheels
Yes I couldn't agree with you more! Disc brakes are always a plus in any case with any car, aftermarket 4 lug wheels are available but not many to choose from. I met a guy back a couple months ago at a swap meetthat had some 5 lug rear axles from a '66 mustang 7.5 rear asking 75 bucks for the pair.
I told him I was converting to 5 lug wheels, I went on to tell that I was also coverting to a built 289 expecting around 300+ Hp
he advised me to go ahead and try to fine either a 8 or 9" complete rear end.
I'll see can I find his tel# but of course you would have to get all the brake assembly to change over, I beleave if you hold out you may find what you need in a salvage yard and simply score the whole rear end
as I have done.
I got mine from a '79 Granada although is a little wider, If you can find a granada that still has the front assembly be sure to get this as well it will work for your front conversion, I was not so lucky the front components were already taken, so I woundup getting what I need from a 64 Fairlane had drum brakes, But atleast I have the correct spindles when I do get ready to convert to disc brakes...
and keep a check on ebag but they can get pretty pricey on there.
Old Jan 5, 2008 | 09:22 PM
musting's Avatar
musting
I found this one up on now good price.
eBay Motors: 65 67 69 70 73 MUSTANG FAIRLANE DISC BRAKE SPINDLES (item 290194846690 end time Jan-06-08 09:02:34 PST)
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
