ting numbers an
Old Jan 13, 2008 | 08:22 PM
68goldstang's Avatar
68goldstang
Default ting numbers an
Where can I find a engine casting number guide? I have a 67 v8 which I was told was a 289 but I have looked at the casting numbers and now i'm not sure what it is. The numbers by the starter are C90E-6015-c or 8015-C there are other numbers 9M4 . I looked at the heads and since they are still on the motor I could make out a 302 between the rockers but is that the engine size they are from?
Old Jan 13, 2008 | 08:46 PM
mustanglover66's Avatar
mustanglover66
Default RE: ting numbers an
you have a 69 302 since 68 was the last year 289 was available. C=60's decade 9= year in decade 0= fairlane/torino line and E= engine part. There is a decoder in the faq section if need more decodeing
Old Jan 13, 2008 | 09:15 PM
68goldstang
I also saw a C90E-B listed as a 69 351W . I couldnt find the coder in FAQ. Was there a C90E 302 block?
Old Jan 13, 2008 | 09:16 PM
68goldstang
BTW the block is a different color than the heads after I pressure washed the motor.
Old Jan 13, 2008 | 09:46 PM
mustanglover66
This is from the FAQ sec. under IV. VIN AND PARTS DECODERS:
interesting reading if you look at the paragraph near the first head casenumber pic it says block casting numbers do not determine CID
http://www.classicmustang.com/casting_numbers.htm
Old Jan 13, 2008 | 10:26 PM
pimp2303's Avatar
pimp2303
this is what i used to find out what i had... its pretty easy also
http://www.fordification.com/castingno.htm
bconboy
Sep 24, 2015 01:55 PM
jstrothe
Sep 24, 2015 12:17 PM
Sep 23, 2015 01:28 PM
2016PP
Sep 23, 2015 09:51 AM
Demodulates
Sep 18, 2015 11:14 AM
