How much valve movement - 351C
Old 01-25-2008, 08:55 AM
my77stang
my77stang's Avatar
Default RE: How much valve movement - 351C
from how he is describing it i believe he is fine.
and just worth mentioning, you guys shoulda seen the slop in the guides of my dads diesel head after a million miles. SO sloppy yet the motor was still running fine. we only tore it down because the balancer bolt holes were screwed up in the crank and the head gasket was leaking water down the side of the block. he was on a budget, and we knurled the guides and reground the old valves. back on the road he is, and will probably run hundreds of thousands of miles again.
my77stang is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
mustangheaven
01-03-2016 11:20 AM
mustangheaven
10-07-2015 10:23 AM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: How much valve movement - 351C
