Ignition options
Old Jan 24, 2008 | 06:21 AM
mortman's Avatar
mortman
Default Ignition options
Been looking into an electronic ignition for better fuel economy and hopefully a little more power? I am running a 289 stock I be leave, not sure what PO did to the motor but is sounds healthy. Not sure what is needed to upgrade, distributor set up, modules ect? Any advice would be greatly appreciated.
Thanks
Old Jan 24, 2008 | 07:54 AM
69thunder's Avatar
69thunder
Default RE: Ignition options
Look into a pertronix unit. They eliminate the points, is very easy to install and has some nice features that a lot of other modules don't. I have one and really like it. Also, it is a whole lot easier than pulling the distributor if you don't have much experience with that. Then you can add on an MSD box or Mallory or any others to get multiple sparks.
Old Jan 24, 2008 | 08:18 AM
my77stang's Avatar
my77stang
yeah petronix is probably easiest and cheapest for you, if you want to go bigger and better look into crane ignition products, they are hands down better than MSD
Old Jan 24, 2008 | 10:58 AM
mustangmatt63's Avatar
mustangmatt63
A Pertronics would be your best bet as they are relatively Cheap and an Easy Install.[sm=gears.gif]
Old Jan 24, 2008 | 11:05 AM
choefle's Avatar
choefle
I would use the Pertronix Ignitor II and Flame-Thrower II coil together.
Old Jan 24, 2008 | 01:46 PM
kalli's Avatar
kalli
ORIGINAL: choefle
+1 on that. same upgrade hear. happy man.
looks kinda stock as the coil is seperate from dizzy.
Put in a massive HEI into a friend of mines car, and the airfilter won't fit anymore and stuff ...
easiest are the pertronix if you don't want to go spending insane money
Old Jan 24, 2008 | 04:26 PM
mortman's Avatar
mortman
Thanks for the input all, ill look into this one for sure
jwog666
Dec 27, 2021 08:09 PM
bradleyb
Nov 27, 2015 07:50 PM
ChampInSD
Oct 2, 2015 04:55 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Wombatnation
Sep 13, 2015 09:16 PM
