T-5 conversion parts PLEASE HELP
Old Mar 16, 2008 | 12:15 PM
  #41
PONYBOY65's Avatar
PONYBOY65
Default RE: T-5 conversion parts PLEASE HELP
i knew it haha
i can also use a late model clutch set up right?
thanks
Old Aug 26, 2008 | 02:50 PM
  #42
neverhit's Avatar
neverhit
Originally Posted by PONYBOY65
yea you could use the first two slip yokes, but you will have to shorten it and change your stock u joints.
If you go with the third one, you dont have to do any cutting or changing your u joints
if you havent bought the transmission mount, fulcrum spacer kit, transmission insulator, and slip yoke; there are kits that you can buy and save your self some money.
this is the cheapest ive seen
http://www.laurelmountainmustang.com/index-1024.htm
or you can always check out ebay, i got the kit for 300 including shipping.
good luck!
I am setting up to do the same thing. Could you please explain which one doesn't require modification? Thanks.
AMAlexLazarus
AmericanMuscle.com
21
Apr 4, 2020 02:16 PM
HRnB
GT350 S550 Tech
Dec 18, 2015 09:35 AM
Nov 10, 2015 11:39 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
