T-5 conversion parts PLEASE HELP
ORIGINAL: PONYBOY65
Hi guys over the past year ive been gathering all the parts needed to convert my automatic to a T-5 and this is what i have so far:
[ul][*]T-5 transmission[*]T-5 Bell Housing[*]T-5 crossmember[*]Modern Driveline Cable clutch kit[*]Fly wheel[*]Clutch[*]Clutch Pedal Assembly[/ul][align=left]I know im missing the slip yoke, transmission insulator, fulcrum and spacer kit.
1. can i use any slip yoke like these: http://cgi.ebay.com/ebaymotors/Trans...2em118Q2el1247
http://cgi.ebay.com/ebaymotors/Ford-...2em118Q2el1247
or does it have to be like this one:
http://cgi.ebay.com/ebaymotors/65-66...2em118Q2el1247
2. is the transmission insulator needed?
3. If im using the cable clutch assembly do i still need the fulcrum and spacer kit?
thanks guys
[/align]
thanks guys
[/align]
http://cgi.ebay.com/ebaymotors/Ford-C4-C-4-T5-T10-T-5-Toploader-Mustang-Trans-Yoke_W0QQcmdZViewItemQQcategoryZ33738QQihZ004QQite mZ140135129069QQrdZ1QQsspagenameZWD1VQQtrksidZp163 8Q2em118Q2el1247
http://cgi.ebay.com/ebaymotors/65-66-67-68-69-70-MUSTANG-T-5-SLIP-YOKE-NEW-USA-MADE_W0QQcmdZViewItemQQcategoryZ140728QQihZ019QQit emZ290200374079QQrdZ1QQsspagenameZWD1VQQtrksidZp16 38Q2em118Q2el1247
Does anyone have an answer? Thank you.
yea you could use the first two slip yokes, but you will have to shorten it and change your stock u joints.
If you go with the third one, you dont have to do any cutting or changing your u joints
if you havent bought the transmission mount, fulcrum spacer kit, transmission insulator, and slip yoke; there are kits that you can buy and save your self some money.
this is the cheapest ive seen
http://www.laurelmountainmustang.com/index-1024.htm
or you can always check out ebay, i got the kit for 300 including shipping.
good luck!
good luck!
I will try to buy a kit for the itemsyou mentioned above.
For my 1966 4 speed, I alreadyhave a:
T-5 transmission
T-5 bellhousing
T-5 block plate
T-5 fork
T-5 throw-out bearing
mustangsteve's ball bearing pedal assembly
Diaphram clutch kit installed
5speed OEM style shift ****. I need the '65-'66 OEM style shift lever and boot.
I will be using the T-5, late model,bellhousing and a hydraulic clutch kit actuatorfrom JMC. Therefore, I don't know if I need the fulcrum kit. I believe this is asimiliar question asyour question 3 in the first post.
Do I need the fulcrum spacer kit with a hydraulic clutch?
Then measure driveline, cut if necessary, and balance.
Thanks.
T-5 transmission
T-5 bellhousing
T-5 block plate
T-5 fork
Thanks.
Who ever said you have to rebalance the flywheel is wrong. You said yours is a 65 with a 289 and the flywheel came out of a 66 3speed manual car. The flywheel will bolt right in, no rebalance needed.
