spark plug gap
Old Feb 16, 2008 | 01:51 PM
SalikDDD's Avatar
SalikDDD
Default spark plug gap
ok so the stock gap on the 289 for 67 is what? like .35 right? well since i have GT40P heads and use different plugs i should set em to the stock gap for the explorer right? which is .54 or no? someone suggested i gap em to .45 or so but i'm confused.
Old Feb 16, 2008 | 05:32 PM
wrenchturner75's Avatar
wrenchturner75
Default RE: spark plug gap
ford changed the gap when they introduced the duraspark ignition system, much more accurate and higher power going to the plugs. old points systems are 35 give or take. durasparks are usually around 45 to 50. if your using points yet id say stick with the 35. if your using a high energy ignition system then you can open the plugs up to 45 to 50, it just takes more current for current to jump the gap hence points with lower voltage needed a smaller gap. id say stick with whatever ignition system your using. this has always worked for me, just my opinion.
BOB ROME
Jul 26, 2023 01:54 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
lmurf60
Sep 24, 2015 10:07 PM
