thermostat orientation
Old Feb 20, 2008 | 09:42 PM
john721's Avatar
john721
Default thermostat orientation
66 289 motor.... does the "spring" or the "button" face the engine when you install the thermostat?
Old Feb 20, 2008 | 09:58 PM
JMD's Avatar
JMD
Default RE: thermostat orientation
Install with most of the thermostat below the housing......
Spring down...
Old Feb 20, 2008 | 10:05 PM
john721's Avatar
john721
So with a thermostat housing that is mounted on the front of the manifold, the spring would be on the motor side, and the Button on the radiator side...?
Old Feb 20, 2008 | 10:13 PM
JMD's Avatar
JMD
ORIGINAL: john721
Sorry,,,, I was in "Chevy Land" for a moment,,, the big part of the thermostat (spring side) goes toward the back of the car.
"Small side" toward the front.
Old Feb 21, 2008 | 03:57 AM
kalli's Avatar
kalli
the spring side regulates how far this thing is open or closed.
if the water in engine is too cold, then the thing should stay closed, so the engine can heat up the water
if the water in engine is too hot, then the thing will slowly open, so you can mix the hot engien water with a bit of colder water from radiator. The hotter the engine, the wider it'll open to allow more water flow to rad.
So that's why the spring side has to be on engine side as JMD describes it
Nick Oliver
Oct 17, 2018 04:22 AM
carid
Jul 8, 2016 09:55 AM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
