390FE and Points
Old Feb 27, 2008 | 02:14 PM
390bigblock1's Avatar
390bigblock1
Default RE: 390FE and Points
very nice, im trying to get mine on the road by this weekend, im stuck on my steering,
Old Feb 27, 2008 | 02:18 PM
retro77's Avatar
retro77
Nice! I dont even know if my steering is good or not. I am starting small to get it where I can drive it and enjoy it for right now.
Old Feb 27, 2008 | 02:22 PM
390bigblock1
thats what im going for too , i dont have paint... just primer right now, and none of my windows roll up and stay up, but it runs!
Old Feb 27, 2008 | 02:24 PM
retro77's Avatar
retro77
Windows...lol...I have a wood block in the driver door keeping the window up.
Old Feb 27, 2008 | 02:34 PM
390bigblock1
haha my windows r my last project, you dont need windows in sacramento, it gets too hot to have them up, and i dont have a/c
Old Feb 28, 2008 | 06:05 AM
kalli's Avatar
kalli
good luck :-]
when you get a timing strobe opt for a model that is bright.
some cheap strobes you can only use in the dark ...
as well try to get a strobe where you can adjust the timing. a standard model where you can't will be good enough to set initial timing, but with a model where you can adjust the advance you can play around more (chekc on total advance etc) .... so if that's in your budget, get one of them.
Kalli
Old Feb 28, 2008 | 08:23 AM
retro77's Avatar
retro77
Here is the one I bought from Sears:
Timing Light, Inductive Advance
Item #: 00921023000
http://www.sears.com/shc/s/p_10153_12605_00921023000P
I ordered it online. Saved me time in that traffic on the 5 from Arco Arena on down....
Also got a charger/tender and a feeler gauge set. I might replace the intake manifold gasket this weekend...we'll see how this goes first.
Old Feb 28, 2008 | 09:13 AM
kalli's Avatar
kalli
i don't know that strobe, but it sounds perfect for what you need.
you can set advance 0-60 and the inductive clips are great (you won't have to pull cables, you can just clamp it around #1 cylinder)
according to manufacturer: "Brilliant white flash easily visible even under direct sunlight."
so it seems to be a good tool for you
Kalli
Old Feb 28, 2008 | 10:56 AM
falconfixer's Avatar
falconfixer
...and some chalk or 'white out' for the timing marks on the crank, eh?
You will soon know the wisdom of the Ancients when you can say you have set points!
Old Feb 28, 2008 | 01:00 PM
390bigblock1
yup chalk helps alot and that timing light works great tthats the one i bought. good luck.
