I think I broke something
Old 03-23-2008, 05:03 PM
Jstang
Jstang's Avatar
Default I think I broke something
I was out driving around in the 66 and went for a "spirited drive" and all of a sudden I hear and feel a large bang from the rear end. So I slow down and get out to see what it could be. No fluid on the floor or no parts missing. So I jump back in the car and start to pull away and I hear and feel as if the rear end is going to fall off and if feels likes its bouncing around![:@]The leaf springs and are fine shocks and so on. I feel it may be the gear. What do you all think it may be? And if it is the rear end gear what should I get and where should I get it?
Thanks
Jstang is offline
Old 03-23-2008, 05:09 PM
67t5ponycoupe
67t5ponycoupe's Avatar
Default RE: I think I broke something
Ready to start buying parts and you don't know what is wrong yet?? Lets troubleshoot it first. Get it home and start tearing it down and we will see what it needs.
67t5ponycoupe is offline
rmodel65
Yukon Cornelius
rmodel65's Avatar
jack it up and see if you got a bad u joint
rmodel65 is offline
Old 03-23-2008, 05:11 PM
Jstang
Jstang's Avatar
ORIGINAL: 67t5ponycoupe
Your right Im jumping the gun. Need to get the hands dirty to see whats wrong.
Jstang is offline
Old 03-23-2008, 05:40 PM
67mustang302
67mustang302's Avatar
Jack the car up and check the u joints, and leave it in neutral with the parking brake off(put some blocks around the wheels still on the ground if you don't raise the front) and turn the driveshaft, if the gear go kaboom then when you turn the driveshaft and move the gear, you'll feel it. Make sure you turn the rear axles at least 1 full revolution.
67mustang302 is offline
Old 03-23-2008, 06:18 PM
Jstang
Jstang's Avatar
ORIGINAL: 67mustang302
Thanks for the tip.
Jstang is offline
Old 03-23-2008, 07:13 PM
moparmatt89
moparmatt89's Avatar
same thing happened to me on the highway,very scary going like 70 and having it happen then totally break. i would be willing to bet that it is the u-joint just like others have said. take a look and see, if it lets loose you will tear apart the underside of the car. i would replace them just to be safe
moparmatt89 is offline
Old 03-23-2008, 07:56 PM
pascal
S197 Section Modder-ator
pascal's Avatar
Funny though...
U-joint usually don't quit all of asudden.
You'll hear that nasty clunk everytime you put it in gear from park when they start going bad, so it's a warning sign.
But you ignore this and drive the car in a spiritual way,lol, it'll just snap on you[8D].
pascal is offline
Old 03-23-2008, 08:36 PM
67mustang302
Bad u joints will often create a constant vibration at certain speeds or loads.
Old 03-23-2008, 09:24 PM
Jstang
Jstang's Avatar
One more question. What causes the U-joints to go bad and where should I pick some up at? Any recomendations on what brand to use?
Jstang is offline
Quick Reply: I think I broke something
