started my floorboard project
Old Apr 13, 2008 | 05:21 PM
  #21
baddog671's Avatar
baddog671
Default RE: started my floorboard project
Good job on the progress you've made so far! Now get that drivers side done!
Old Apr 14, 2008 | 06:27 AM
  #22
65mustang's Avatar
65mustang
thanks for the comments and advice!!
i found the plexi cover for the cowl vents, plan on having that also, i do have to change the front glass and plan to pull the fenders so that will be the time to cut the spot welds andinspect/ repairin there but i think i will use the cowl cover all the time to prevent any more damage, i have the wing windows for air, still thinking on that task
did a little more to it yesterday afternoon, seam sealed all edges inside and undernieth, primer sealer, undercoated, got the passenger side door closing better, vaccuumed up the mess andhad a cold beer
now i'm ready for the driver side, i have the toe panel and the floorboard for this side and plan on doing the toe panel first then fitting the floor pan, may start on the toe panel this afternoon
Old Apr 14, 2008 | 07:26 AM
  #23
baddog671's Avatar
baddog671
If it was me (and too late for the passenger side), while that frame rail was wide open, I would have dumped a bunch of rust protectent in it.
Old Apr 14, 2008 | 07:35 AM
  #24
65mustang's Avatar
65mustang
i did, i just didnt get a pic of it, i cleaned it out, scraped it down wiped it out with laquer thinner, all was in great shape then primed it and undercoated it before installing the pan
Old Apr 14, 2008 | 07:45 AM
  #25
baddog671's Avatar
baddog671
Good job
Old Apr 14, 2008 | 07:46 AM
  #26
Adrenolin's Avatar
Adrenolin
You still can.. Take to any shop who do undercoating. They can spray inside all these tight areas with long tube adapters. They go up through the dran holes and are able to spray and cover inside the frame rails, rocker panels, etc. Worth every penny too even though its not too expensive.
Old Apr 14, 2008 | 04:05 PM
  #27
65mustang's Avatar
65mustang
ok so after some time to think over the driver side i went at it, got it cut out, got the toe panel fitted.....time for a beer and stop for today
StalkerGT
Sep 25, 2015 02:41 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
5.0 kevo
Sep 3, 2015 06:24 PM
