thermostat temperature
Old Apr 13, 2008 | 01:28 PM
javier146's Avatar
javier146
Default thermostat temperature
Since I was having overheating issues, I took the thermostat out. Now the engine doesn't heat up past 162, should I run it like this, or get a lower degree thermostat?
Old Apr 13, 2008 | 01:34 PM
FrostByte's Avatar
FrostByte
Default RE: thermostat temperature
Sounds like overheating was caused by bad T-stat. Install a new one of proper temperature range.
Old Apr 13, 2008 | 01:35 PM
Mustangdemon67's Avatar
Mustangdemon67
you should run it with a thermostat. just put a 160 in there if you want. maybe your radiator just needs to be flushed. but if you run it with no thermo, then the coolant isnt going to have much time to cool down in the radiator
Old Apr 14, 2008 | 01:33 AM
Montanas Mustang's Avatar
Montanas Mustang
Your thermostat is there to create enough back pressure (even when open) to force the coolant to the back of the block. Running without one is asking for trouble. Fulsh your system, check your hoses, make sure your radiator is good (not half-full of gunk). 160 is a little cool in my opinion but still acceptable. I would shoot for being able to run with a 180.
Old Apr 14, 2008 | 07:50 AM
69thunder's Avatar
69thunder
180 is what i run. Without a thermostat is not a good idea.
Old Apr 14, 2008 | 02:28 PM
67mustang302's Avatar
67mustang302
I run a 195, and it's a very hot summer envorionment here. No overheating. The only way a t-stat will cause overheating is if it's bad.
Old Apr 14, 2008 | 03:53 PM
jlg2002's Avatar
jlg2002
You need to go into the FAQ section and read the post about overheating. Personally, here on the lower west coast, I like a 160 in the summer and 180 in the winter ( if it starts getting too cold). If your radiator has enough thermal effeciency any thermostat will work. unfortunately the mustang does not have a really great radiator to start with so there's room for improvemnts. Please take a look in the FAQ's. I'm sure you'll gain an exception education on the issue.
Old Apr 14, 2008 | 05:31 PM
JMD's Avatar
JMD
ORIGINAL: 69thunder
I place my vote HERE....
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
svfetter
Oct 5, 2015 11:39 AM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
