need fuse box help
Old Apr 14, 2008 | 11:56 PM
mark66's Avatar
mark66
Default need fuse box help
Hello all, at the fuse box I have power to the dome light fuse and the cig lighter fuse only and all the other fuse tabs (radio, turn signals, and dash lights) are dead. It is not blowing fuses it's that there is no power from the battery to those particular tabs. they worked fine before today. Any thoughts?
Thanks Mark
66 coupe
289
Old Apr 15, 2008 | 06:10 AM
67 evil eleanor's Avatar
67 evil eleanor
Default RE: need fuse box help
Your key needs to be on. The key switch may be bad. You can track this down easy with a test light.
Old Apr 15, 2008 | 09:25 AM
mark66's Avatar
mark66
thanks 67 evil eleanor, I'll check it out.
Old Apr 15, 2008 | 10:40 AM
mark66's Avatar
mark66
Well, it seems that the master junior electrician (me) that did a fine job repairing someone else's sloppy wiring job, forgot to tighten down the nut on the back of the ignition switch. Thanks again 67 evil eleanor!
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
daltron
Apr 28, 2016 08:10 PM
daytooday
Sep 20, 2015 10:55 AM
cbird1177711
Sep 2, 2015 04:12 PM
