Weld/assembly manual question
Old Apr 15, 2008 | 05:16 PM
67fastbackshell's Avatar
67fastbackshell
Default Weld/assembly manual question
I'm a little confused about how to follow the assemlby manual. If i turn to the first of the manual it shows a more or less complete frame assembly. Then, if i turn a few pages more the first thing it shows being put together is the radiator support, followed by the frame rails, foor supports, and firewall.
I guess my question is, what is the real process of assembly?? Did they assemble the front apron. frame rails, shock towers, radiator support, and floor pan supports seperately, then attch the firewall, followed by the front end assembly i just described, follwed by the floor pan???
Also, i still cant find the frame dimensions/measurements in any of the manuals. Can someone point me in the right direction.
Thanks!!!
Old Apr 16, 2008 | 01:39 PM
67fastbackshell
Default RE: Weld/assembly manual question
To the top
Old Apr 16, 2008 | 02:56 PM
jlg2002's Avatar
jlg2002
The only dimensions i've found are in the service manual (chapter 17) and it shows the distance between the front and rear frames (side to side), the front frame and rear frame widths.
Tivo304
Aug 28, 2023 12:19 PM
04stangman
Sep 17, 2015 01:45 PM
Mustangmalo
Sep 6, 2015 05:22 PM
