widest tire?
Old Apr 18, 2008 | 08:49 AM
baseball87b's Avatar
baseball87b
Default widest tire?
what is the widest tire i can put on the rearson my 69 mach 1? without doing any modifications.
Old Apr 18, 2008 | 08:56 AM
tyler72's Avatar
tyler72
Default RE: widest tire?
Depends on the backspacing of the wheel, and also on the height of the tire. I am running a 255/70/R15 on the back of my 72. They look awesome from any angle, but, the pass. side one rubs if you hit a bump just right.
Old Apr 18, 2008 | 10:52 AM
andrewmp6's Avatar
andrewmp6
Heres a chart http://www.dodgestang.com/Tire%20Fit...de%2069-70.pdf
Old Apr 18, 2008 | 12:09 PM
cprstreetmachines's Avatar
cprstreetmachines
Should be able to fit a 315 at least. That's what we have in a 67, and a 70 in a smidgin' bigger.
Old Apr 18, 2008 | 12:45 PM
SalikDDD's Avatar
SalikDDD
i saw 335's on a 65 last week seemed fine to me
Old Apr 19, 2008 | 02:26 AM
boogerschnot's Avatar
boogerschnot
I think a 275is the biggest you can go with room to move..and no rubbing at stock height
Old Apr 19, 2008 | 08:13 AM
andrewmp6's Avatar
andrewmp6
A lot of will it fit is your ride height lower the car more likely a big tire will rub.
Old Apr 19, 2008 | 01:08 PM
chillininnh's Avatar
chillininnh
The largest tire I have seen installed on the rear of a 69 without major modification was 295/35/18. No mods to the axle, but a BFH was needed to clearance a couple of areas in the wheel well. Here's the thread:
http://www.1969stang.com/mustang/for...ead.php?t=2301
This guy has some sweeeeeeeet cars!!!
Old Apr 19, 2008 | 01:35 PM
urban_cowboy's Avatar
urban_cowboy
Your leaf springs and tire diameter are going to be the biggest factor. I have MT 26x10.5 on mine with no problem but if your leaf springs sag or you run a taller tire, you are going to have issues. I think, anything much about 10.5 wide is going to be dependent on you specific car.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
