Intake question
Old Apr 22, 2008 | 07:54 AM
pwrl3ss's Avatar
pwrl3ss
Default Intake question
Sorry if thismay be a beated subject but, I'm thinking about pulling out the 2V carb/intake on my 289 and throwing on either my 302 OEM 4v intake/carb or going with Edelbrock's Performer intake/carb setup. Performance wise, are they going to be about the same? If I recall right, the difference between HP with a 302 2v vs 4v was about 10HP. Would the Edelbrock setup be a bit more?
With the OEM carb, I think I would have to rebuild it (there some cobwebs inside of it[:-]). Is that a task not for the unexperienced?
The 289 is pretty much stock except the PO told me he put a "warmer" cam in there when it was rebuilt.
Thanks
Old Apr 22, 2008 | 08:08 AM
baxsom's Avatar
baxsom
Default RE: Intake question
why put another heavy steel intake on?
go with the aluminum one.
Old Apr 22, 2008 | 08:43 AM
Starfury's Avatar
Starfury
Definitely go with an aluminum manifold. Unless you're restoring for show points, I don't see any reason to ever put a cast iron manifold back on an engine. The weight savings alone are worth it, IMO.
Either the Edelbrock Performer Plus or the Weiand 8124 will work well as a stock upgrade. The Weiand is a newer, slightly better design, but if you run across an Edelbrock for cheap I wouldn't pass it up. It is NOT simply an aluminum version of the factory cast iron manifold, as some people seem to believe.
With a good manifold and a properly tuned ~500CFM carb, I'd expect about a 10hp increase. The real benefit will be in throttle response and top end pull.
Old Apr 22, 2008 | 09:21 AM
69thunder's Avatar
69thunder
ORIGINAL: pwrl3ss
Thanks
Go with the edelbrock. It will be a little more power but more importantly, more user friendly.
Old Apr 22, 2008 | 01:12 PM
65Coupester's Avatar
65Coupester
Anyway you are not really taking advantage of the 'warmer' cam without a better flowing intake.
Tivo304
Aug 28, 2023 12:19 PM
Luke9222
Oct 22, 2015 11:55 PM
Mustangmalo
Sep 6, 2015 05:22 PM
