Replaced Fuel Pump, now won't run help please.
Old May 6, 2008 | 10:42 PM
  #21
Gun Jam's Avatar
Gun Jam
Default RE: Replaced Fuel Pump, now won't run help please.
How long did you crank on it before checking for fuel at the filter? Might have been coincidence and it just needed a sec to prime up???
Generally a crack in the out line on the pump only results in fuel leaks not a failure to prime. A crack in the IN line WILL result in failure to prime with no or very low volume.
Sounds like it was just a bad pump.
Does the fuel filter fill all the way now or still halfway?
Good hunting. Noting a like beating down a problem child.
-Gun
Old May 6, 2008 | 11:08 PM
  #22
Waffles's Avatar
Waffles
From: Detroit; where the weak are killed and eaten.
Fills up all the way now. Mayb have been the pump. who knows. all that i care about is that its running.
I cranked on it alot. a LOT, before switching everything out. I gave iit every opportunity to please me. It neglected to.
djbigskrilla
Sep 20, 2022 01:04 AM
Design1795
Jan 24, 2017 10:38 PM
Design1795
Aug 24, 2015 04:41 PM
drumhedd2005
Aug 13, 2015 09:59 AM
89blueslug
Aug 10, 2015 07:20 AM
