65 instrument cluster ground
Old May 5, 2008 | 04:35 PM
jgibbs22's Avatar
jgibbs22
Default 65 instrument cluster ground
HEy Everyone:
Where and what grounds the instrument cluster lights and the constant voltage source? The 66 diagram shows a wire running to a spot under the dash, but I don' see anything for the 65. Any info and a picture would be awesome! thanks everyone!
J
Old May 5, 2008 | 08:37 PM
ThanksDad's Avatar
ThanksDad
Default RE: 65 instrument cluster ground
I have had a problem with my 66's gauges for the last year. We think it is a ground problem. I ended up running a new wire from the IVR screw to the frame just above the steering column.
This is not the factory situation but I can't see any reason this would be a problem.
Old May 6, 2008 | 05:06 AM
kalli's Avatar
kalli
I haven't check on the wiring diagram, but my cluster gets ground of the dash (the metal). when I hook up all cables on the cluster and turn on the lightswitch the lights in cluster come on at the moment I put the cluster back into the dash. make sure your dash has ground. that might help then.
Kalli
Old May 6, 2008 | 09:59 AM
davesanborn's Avatar
davesanborn
I'm not sure on a '65, but on a '66, there is a black wire on the backside of the instrument cluster with a bullet type connector. It connects to its bullet connector counterpart that should also be a black wire coming off of the center area of the metal dash structure area behind the cluster.
Dave
Old May 6, 2008 | 11:35 AM
jgibbs22's Avatar
jgibbs22
Thanks guys!! I will get in there again today and see what I can find. If I cant find anything I will snap some pictures and post them.
jwog666
Dec 27, 2021 08:09 PM
5.0muscle
Jan 11, 2016 01:17 PM
andrew1969
16
Jan 8, 2016 02:48 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
