old iginition switch won't turn? PROBLEM SOLVED
Old May 16, 2008 | 07:35 PM
66JameStang's Avatar
66JameStang
Default old iginition switch won't turn? PROBLEM SOLVED
Well I am trying to take out my old ignition switch but unfortunately The switch will not turn so... How do I disengage it to remove the cylinder so I can remove the bezel ultimately enabling me to remove the switch???[&:] This sucks I may just go mad and drill that junk out!
I even broke off my original set of keys trying to turn the cylinder to the on and off position?...[sm=badbadbad.gif]
Old May 17, 2008 | 02:47 PM
ninteen66mustang's Avatar
ninteen66mustang
Default RE: old iginition switch won't turn?
how long did you fiddle with it? it took me a long time but eventually it just came out like it was supposed to... I would just wiggle the paperclip or whatever while turning the key... also, you could try loading it up with wd40 to make everything move better.
good luck.
Old May 17, 2008 | 03:46 PM
66JameStang
[sm=badbadbad.gif] I got a new tool last night and decided this would be a great oppertunity to use it, I nice 5lb sldie hammer from harbor frieght did the trick!
I am gonna go replace it right now and hopefully cruise tonight
Design1795
Jan 24, 2017 10:38 PM
MXBT187
Aug 20, 2015 02:36 AM
1st 4 eyed fox
Aug 15, 2015 02:16 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
drumhedd2005
Aug 13, 2015 09:59 AM
