por15
Old May 19, 2008 | 07:15 PM
drm_stang's Avatar
drm_stang
Default por15
I havedecided to use por15 on my engine baybut have one question for any one who has used this product before. Do you think i will be able to spray a semi flat black paint over top of the por15's gloss finish with out it reacting, cracking, separatingwith each other.??
Old May 19, 2008 | 07:29 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: por15
i believe they offer the por15 paint in semi flat too
Old May 19, 2008 | 07:54 PM
coda618's Avatar
coda618
Default RE: por15
In my experience, the por 15 finish/sheen is uneven and should be topcoated in visible areas. I am using it on my engine bay as well. You will have to sand cured por 15 to get topcoat to stick. The easiest way to do it is to get the por primer. It is made to be compatible with the por 15, then you can topcoat that. However, to avoid sanding, you need to follow the directions. You have to spray an initial dry dusting of primer on the fresh coat of por 15. This way the primer bonds to the por 15 chemically. It pretty straight forward. Sanding the cured por 15 to prep for topcoat is a pain in the a** and it is a must to topcoat cured por 15. Try it this way, much better.
You can read the direction on the por 15 websight.
Good luck.
groho
Sep 12, 2011 10:17 PM
wumarshall82
Sep 3, 2008 09:10 AM
Toddman0025
Apr 25, 2008 10:57 PM
Toddman0025
Apr 24, 2008 10:14 PM
Loza_69Mach1
Apr 10, 2007 09:36 AM
