gas tank guage problem
Old Jun 15, 2008 | 04:41 PM
Randy168's Avatar
Randy168
Default gas tank guage problem
I have a 66 mustang. Fuel level does not register on the guage. I bought a new guage, still shows the same. I had the sending unit out of the tank and put it in the full position it only would register half a tank. I think it may be a sending unit problem. I have a good electrical reading. Has anyone else had this problem or an idea for a solution? Thanks
Old Jun 15, 2008 | 04:50 PM
Hot70Mach1's Avatar
Hot70Mach1
Default RE: gas tank guage problem
no input but i have the same problem. sorry but im going to piggy back off you and try what ever it is that fixes yours.
Old Jun 15, 2008 | 04:54 PM
65Coupester's Avatar
65Coupester
Well, since you replaced the gauge the only thing left is the constant voltage regulator, sending unit(rheostat) and the float.
The CVR is a rectangular box on the back of the dash module. Check the CVR with a volt meter. It should read 12 volts on 1 terminal and 5 volts on the other(that goes to the gauges.
Check the sending unit, off the car, by connecting an Ohm meter fron the terminal to the mounting plate. It should read about 25 to 150 Ohms, low to high.
If everything is good and it still doesn't register when fuel in the tank then the float is probably leaking.
Old Jun 15, 2008 | 09:59 PM
ThanksDad's Avatar
ThanksDad
There is a very easy way to ground the sending unit without removing it from the tank. When you ground it if the gauge jumps to full the sending unit is ok. Now the bad news: You need someone smarter than me to tell you how to ground it. Someone helped me and I can't remember how he did it.
Old Jun 15, 2008 | 10:06 PM
67 evil eleanor's Avatar
67 evil eleanor
Before I went too far, I would clean the terminal VERY good that goes on the stud from the sending unit. Often corrosion acts like a resistor and can give a false reading. Its easy, free and may solve your problem without work and cost.
Old Jun 15, 2008 | 10:26 PM
WD0AFQ's Avatar
WD0AFQ
Excellent advice. The sending units are cheap and easy to install in our cars. I think around 20 bux or so.
Dan
Old Jun 15, 2008 | 11:18 PM
gibsonxplayer88's Avatar
gibsonxplayer88
make sure the wireing that screws into the sending unit is on all the way, it feels really goofy because it feels like the thread keeps going but that could be causing you to get a bad connection.
Old Jun 19, 2008 | 07:40 PM
Randy168's Avatar
Randy168
Thanks for all the help. The constant voltage regulator did the job!
Randy
Old Jun 20, 2008 | 03:49 PM
quantumaxis's Avatar
quantumaxis
In my 68 the fuel float broke twice and i just replaced it and it worked it just not fun draining the tank
Oct 7, 2015 07:02 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
zachary1988
Sep 4, 2015 03:04 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
