How Much Dynamat or FatMat
Old Jul 12, 2008 | 08:24 PM
MonsterB's Avatar
MonsterB
Default How Much Dynamat or FatMat
How many square feet will it require to cover the interior of my 66 coupe? I found it on ebay for half the price of anywhere else. It comes in 40 sqft rolls and 100 sqft rolls. I assume that 100 sqft will be enough for the floor pan and the roof. Is this the case?
Old Jul 12, 2008 | 08:32 PM
ky's Avatar
ky
America ftw
Default RE: How Much Dynamat or FatMat
i believe it only takes about 75 sq ft to do the whole inside + some in the trunk + double thick in some areas.
Old Jul 13, 2008 | 02:45 AM
4reboy's Avatar
4reboy
I think I orderd 140 sq feet of eDead when I did my car, I covered everything, firewall, inside the doors, floor, roof (twice I think), trunk, and some of the wheel wells. I used almost all of it, maybe have 10-20 sq feet left. So if all you are doing is the floor pans and roof, then 100 sq feet will be more than plenty, you can probably easily get by with 80. I recommend doing the firewall if you can, or at least some of it to cut down on engine and road noise. and if your windows are out of your doors drop in a few sheets inside the door. If the windows are in, and since its a 66, it might be hard to get the sheets in the door, for my 69 though it was a piece of cake.
but defintiely do the floor pan, roof, and trunk, thats where most of your road noise will be coming from. and it really does make a big difference
Old Jul 13, 2008 | 03:05 PM
pnandy's Avatar
pnandy
say i want to repaint the trunk down the road how hard is it to remove the dynamat fatmat etc?
Old Jul 13, 2008 | 03:18 PM
4reboy's Avatar
4reboy
paint over the dynamat, or build a custom trunk like i did as well as others that has carpet and all that. If you are just going to paint it it probably isn't worth installing it in the first place, because once its on there its on pretty good, even though you can get it up with some heat and time.
Old Jul 13, 2008 | 03:40 PM
baddog671's Avatar
baddog671
I posted a thread on here around January with pictures and stuff about how much sqft you need to do the interior. 100sqft will be enough for what you need to do for sure. 40 would cover the floor nicely,the rear wheel wells, and maybe a few small sections, but not enough to do the whole interior
I wish the search function workd
Old Jul 13, 2008 | 08:44 PM
juansp67's Avatar
juansp67
here you go
https://mustangforums.com/m_4426786/tm.htm
69FB
Aug 18, 2015 08:50 PM
fox3
Feb 6, 2007 01:41 PM
nualln
Jul 26, 2005 01:25 AM
nualln
Jul 18, 2005 11:17 PM
