water pump help
Old Jul 13, 2008 | 02:35 AM
valley firearms's Avatar
valley firearms
Default water pump help
Well, my ritual "break something everytime I go out" is still good. You will remember back when I got the engine running I blew the heater core. The next time out I blew the gasket between the plate and my water pump. I blew the gasket again. I was just wondering if they make a water pump that turns slower. I do have the March underdrive pulleys on. Is it possible to alter the impeller in my aluminum water pump to decrease psi?
Old Jul 13, 2008 | 03:25 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: water pump help
maybe get an electric pump? i imagine your spinning the motor up there with the stroker and all. also maybe add a restrictor for the heater core 5.0s are bad about blowing them esp with aftermarket non restricted hoses
Old Jul 13, 2008 | 03:41 AM
valley firearms
I had an electric pump but sold it before I put the engine together. I couldn't run a heater with the pump so I sold it. Later I seen where a guy tapped off his radiator for the heater hose. Now that I have the march pulley set up I don't know if it would be feasible to switch everything now.
[align=left] [/align]
Old Jul 13, 2008 | 07:03 PM
Aussie66Fastback's Avatar
Aussie66Fastback
electric water pump
electric heater
thats what i am trying to do with my GT.
i would look at a different size pulley before trying to modify the impeller
jwog666
Dec 27, 2021 08:09 PM
jerrytubes
Oct 23, 2015 12:11 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
